Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 04-17-2024, 06:50 PM
3fastgtos 3fastgtos is offline
Default Filled 455 short block for sale
This is a little weird guys because I don’t remember every detail.
About 2017 I bought an engine Frank (All Pontiac) was listing for a friend who had passed. I sold the heads to lower the compression and installed 87cc heads.
It’s a 455 filled to the soft plugs. Steel 4 bolt straight main caps with arp studs. Lifter valley brace
Scat 4.21 forged crank
6.8 Callies Comp Star h-beam rods
CP gas ported pistons with a slight dome.
Moroso oil pan.
Comp solid roller cam .750 lift? Ground at 110? [email protected]? Not exact but close.
With 335 cfm (87cc) Edlebrocks this engine made 735hp. It ran 6.40s in a 3400lb car at 3200 feet.
I’m keeping the heads for a future blown project so just the short block is for sale.
$3500 plus shipping.
Old 04-17-2024, 09:20 PM
slowbird's Avatar
slowbird slowbird is offline
How much dome? What was compression with the 87cc heads?
Old 04-17-2024, 09:53 PM
Pretty sure it was just over 11:1
Old 04-23-2024, 03:48 PM
I’ve changed my mind on keeping the heads. They’re 335cfm (87cc) Edlebrocks with T&D 1.65 shaft rockers. All this engine needs is an intake and carb.
$7,000.
Old 05-10-2024, 05:49 PM
Found the cam card, I was close. It’s [email protected] I&E, .750 lift, ground 110
Old 05-10-2024, 11:18 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
What is the bore of the block, and where are you located?
Old 05-11-2024, 11:22 AM
4.19 bore
Just ran across Franks old ad, it’s an Ohio forged 4.25 crank for a total of 468”
I’m in South Dakota
Old 05-20-2024, 01:37 PM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
pm sent
Old 05-21-2024, 09:11 AM
Vince GTO's Avatar
Vince GTO Vince GTO is offline
Also interested if still available?
