Old 04-29-2024, 11:04 PM
BOB VIDAN BOB VIDAN is offline
Default Remote Mirror Parts
Have a few remote mirror parts that someone must need before I toss them. Listed by the picture:
Picture 1,2 - glass w/cables. 1 glass dated 2-DMI-4, 4 1/2" diameter, cables are 39"
2nd glass dated 10-DMI-5, 4 1/4" diameter. cables are 20" $10.00 each
Picture 3 - believed to be 62 and 63 front bezels, both the same, numbers on 1 are 14-757, the other is D60167-402. $10.00 each
Picture 4 - control wands. All are different, $7.00 each
Picture 5 - mirror bases, 1 numbered 9780049, the other numbered 430-D60228. $7.00 each
Picture 6 - head and base, base numbered D-60198-402, the head is numbered D-60198-401 and is about 4 3/4" diameter. $15.00
All pieces are in very nice condition and will be shipped at cost. PM if interested. Make an offer on the lot.
ID:	632903   Click image for larger version
ID:	632904   Click image for larger version
ID:	632905   Click image for larger version
ID:	632906   Click image for larger version
Practicing social distancing for 65+ years
Old 04-29-2024, 11:17 PM
Picture 6
Old 06-26-2024, 06:04 PM
Scrapped
Old 10-06-2024, 01:48 PM
SD421's Avatar
SD421 SD421 is offline
Bob, I sent you a Private Message
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 10-06-2024, 07:03 PM
Any idea what scrapped means?
