Old 05-01-2024, 08:02 PM
locomotivebreath's Avatar
locomotivebreath locomotivebreath is offline
Default Read these plugs
How do you guys think these plugs look ? I have about 1700 miles on them on a fresh 406 with 10.00.1 . I ran 5 gal of leaded 110 once - made no noticeable difference . I poured in a can of octanium from VP a few hundred miles ago just because I had it - no difference . Smells just a tad rich at idle but runs fantastic . No hint of detonation and gets excellent mpg . 1st pic is # 1 , 2nd is #8
ID:	633002   Click image for larger version
When I wore a younger man's clothes
Old 05-02-2024, 04:52 AM
Tim Corcoran's Avatar
Reading the plugs on a street given car doesn't tell you much. Is it telling you idle, cruise or full throttle? As you said it may be rich at idle or low speed
Tim Corcoran
Old 05-02-2024, 06:27 AM
steve25 steve25 is offline
They look fine for the average way the motor is used that put those miles on the plugs, extended full throttle maybe a different story and can only be determined with a fresh set of plugs and 3 or 4 full throttle runs up through the gears with no idle time after each run.
Old 05-02-2024, 07:24 AM
Thanks , those are Delco 7 plugs that are like a r44 I think . I pulled a couple just looking for any signs of detonation because I’m paranoid . I run 160 thermostat , it doesn’t get very hot even at 70 with the ac on and is getting 14-16 mpg with 3.90s & Muncie . I cleaned up the idle , running the screws in just about 1/4 turn and driving the last few month weather permitting . I think I’ll jest leave it alone now .
Old 05-02-2024, 10:29 AM
Singleton Singleton is offline
.. https://youtu.be/boo8O8FLsdU?si=qgGQSgHhE1QksRns
66 GTO, 495, M22, Strange S-60 w/4.10
Sold new at Ace Wilson's Royal Pontiac
http://www.youtube.com/watch?v=cUHC-Z8xhtg
Old 05-02-2024, 04:24 PM
Schurkey Schurkey is offline
1. It would help enormously if you'd crop and resize pictures so the detail that mattered was more prominent.
2. Given the leaded fuel, and the additives, I don't think anyone can say for sure what's going on in that chamber based on the color of the porcelains. I haven't seen brown plugs since the lead was taken out of gasoline.
3. For 1700 miles, either the photo wasn't focused sharply enough, or you've got a lot of rounding of the center electrodes.
Name:	Pontiac spark Plug 1.jpg
ID:	633083   Click image for larger version
Name:	Pontiac spark Plug 2.jpg
Old 05-02-2024, 04:46 PM
bob d bob d is offline
Default octanium VP
tried using that crap. turned my plugs red. Made me nervous. called VP they said it was normal fouled the plugs. started worrying about the top of the pistons. changed plugs I was ok. Thanks.
Old 05-02-2024, 06:30 PM
I was wondering if the octane booster was responsible for the color . I think I’ll start over with fresh plugs and high ball the additives & race gas . I have a set of R43s & R45s delcos . Is there a preference - it’s an iron head 406 .
Old 05-02-2024, 09:16 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
I would use the 43`s.
