Old 05-03-2024, 09:10 AM
cadtech cadtech is offline
Default Tie Down Classic Car
What is the best way to tie down a concourse car in an enclosed trailer without damaging the frame or suspension paint?
Old 05-03-2024, 09:12 AM
J.C.you's Avatar
J.C.you J.C.you is offline
Tire straps
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
The Following 2 Users Say Thank You to J.C.you For This Useful Post:
Old 05-03-2024, 09:36 AM
E-track rails fastened to the subfloor will allow positioning of different wheelbase vehicles.
A HD racheting strap setup then secures each tire/wheel combo to the E-track without chafing any body or suspension parts.
Best to you with your Pontiac in Concours judging!
Old 05-03-2024, 09:49 AM
Formulajones's Avatar
tire straps are probably the most common these days for stuff like that. They are pretty straight forward and easy to use if you have the rail system on your trailer.
Most of these cars also had notches in the frame for "T" bolt straps that works perfectly fine and doesn't hurt paint. They actually fit inside the frame and ride. That's how it was done back in the day on trains and such.
I typically use that and have the trailer setup so it takes a very short strap directly to the floor so it doesn't interfere with the body or any suspension parts. You'll find those slotted holes in the frame usually in front of and behind the front tires and they are typically at the rear around the tail pipes.
https://youtu.be/XqEydRRRwqE
Old 05-03-2024, 12:48 PM
72projectbird's Avatar
I usually go thru the wheels on my cars, unless the wheels don't have an opening big enough for the straps to go thru. Then I go around the control arms and over the rear axle.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 05-04-2024, 05:32 PM
geeteeohguy's Avatar
Tire straps, hands down. I've hauled hundreds of cars, and tire straps have zero impact on the car or its parts.
Jeff
Old 05-04-2024, 05:51 PM
Rachelsdad's Avatar
Another vote for tire straps.
Quick anecdote:
When I took delivery of my two '56 Safaris in August, the transporter tightened the straps so much that the underinflated front tire's bead on one of the cars broke. While most of us here have had the experience of mounting tires, getting the bead to snap back in while still on the car was a new one for me. I had to put my roller jack on the trailer to lift the car enough to take the weight off the wheel. (This was an open trailer, and it was pouring rain at the time, too, just for extra fun.)
Moral of the story: make sure your tires are properly inflated before you tighten the straps!
Lewis
Lewis Rosenthal
'63 Bonneville Convertible
'56 Safari
'82 Firebird SE
Old 05-04-2024, 07:00 PM
vertigto's Avatar
vertigto vertigto is offline
Who sells some good straps?
Old 05-04-2024, 08:38 PM
Cardo's Avatar
Cardo Cardo is offline
https://www.macscustomtiedowns.com/s...e-block/c/114/ a bit pricey, but considering how much you have invested in the car well worth it.
"I know just enough to keep me here, but not enough to get me out"
