Old 05-04-2024, 05:03 PM
Skidmark's Avatar
Skidmark Skidmark is offline
Default 72 lemans factory paint....is lacquer?
Does anybody know for sure if Pontiac was using lacquer to paint cars built in 72?
I think I read that somewhere, but was still not positive.
Also thought I remembered if you rub some chemical on it it would rub the paint off confirming it is lacquer.
Old 05-04-2024, 11:16 PM
If you put lacquer thinner on lacquer the paint will come off. If you leave it on a while gasoline will soften it also.
The Following User Says Thank You to Goatracer1 For This Useful Post:
Old 05-05-2024, 12:55 AM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Our '76 Buick A-body still had lacquer. Built in Fremont.
The Following User Says Thank You to hgerhardt For This Useful Post:
Old 05-21-2024, 02:28 PM
skunkwerks's Avatar
skunkwerks skunkwerks is offline
Default Lacquer
Lacquer was used all the way to 1987 or 88 on most GM cars. Some got enamel and the first BCCC paints. Early 90's is when most cars were painted BCCC.
You should be ok if your car is original paint.
White/Blue 71 455 HO T/A Auto
Blue/Blue 71 455 HO T/A 4 Sp
White/Sandalwood 71 455 HO T/A 4 Sp
White/Black 70 RAIII T/A M21/373 (stripper)
Carousel Red/Black 69 GTO Judge 4 Sp
2002 Firehawk Red/Black 6Sp
