62 389 Oil Leaks
Have a nasty oil leak coming from the rear main seal. The rope style seal is new and I am wondering if there is an updated seal or something I missed.
With rope seals it’s very hard to not have any stray shards of the seal from getting under the cap.
When I was using rope seals I would grind a small oval recess in the cap around where the seal can stick out just in case, so the cap would not sit cocked. It’s also necessary to put a very small dab of sealer on each end of the seal and this recess helps to use a good amount of sealer to join things up. Also a lot of gasket sets come with both rope seals since there’s one size for 3” main cranks and 3.250” main cranks. You don’t want to have used the wrong one. Did you have both to pick from?
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 05-06-2024 at 02:55 PM. |
Then thers's this one piece seal from Butler & BOP
https://butlerperformance.com/i-2445...bop-rms18.html |
And an installation video on how to install the 1 piece seal
https://www.youtube.com/watch?v=GQmfLtyMCFw |
The 1 & 2 piece neoprene gaskets are the better option if installed right & the serrations on the crank arent too rough. Also, be sure its not the oil pan U seal gasket, the rubber U seals are notorious for leaking and will look almost the same as a rear main leak. Best option for that is using the thick cork gasket & a good quality sealer. |
