Rear defrost w switch and wires $200
Auto console w shifter no top plate $350 Black bucket seats w headrests need to be recovered but will get you there until you're ready $400 Rear seat $150 Black standard door panels w power window cut outs $250 (driver quality) presentable but have been wet Seat belts rough shape but restorable w shoulder harnesses $125 Front air baffle for ac and 400 cars $350 Upper baffles one has been modified other in touched $50 Front valence w lights $200 need at least one lense but sheet metal is solid Front hood latch $175 original Dynacorn repro latch in box $110 NPD 400 hood new w closed scoops $450 Front bumper support and headlight surrounds $350 Power window tracs and motors $300 missing one quarter motor Fiberglass 400 hood used heavy weight glass I think it's bolt on will have to double check $150 Ac control $200 Original solid deck lid some Dings but solid $150 New Repro 4 speed pedals $80 (2) Repro clutch pedal only new $30 Many ac parts and dash pieces and miscellaneous Just ask pm for pics Roof section solid and saveable for you vinyl roof Front subframe and disc brake set up $450 Steering column w key and mediocre wheel $75 Compete set of 14x7 rally's (ks code not 69) w good trim Rings $175 Offers and trades considered Can bring to Norwalk if paid first Will try and update as things come Off
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
Both hood latches sold, metal 400 hood and scoops sold, window trim sold, headlight bezels sold, dash sold
Lower portion of rear seat sold
Rear defrost is parts $100 for switch housing and blower but you are paying for the switch everything else might now be saveable
Front lower air baffle sold thank you Ames and John
norwalk bump
many parts have sold many available
Auto console wo shifter no top plate $250 Black bucket seats w headrests need to be recovered but will get you there until you're ready $350 Front valence w lights $200 need at least one lense but sheet metal is solid NPD 400 hood new w closed scoops painted (carousel red) $450 Ac control $200 Repro clutch pedal only new $30 Many ac parts and dash pieces and miscellaneous Just ask pm for pics Compete set of 14x7 rally's (ks code not 69) w good trim Rings $175
Bump
pre norwalk delivery bump
Is dash panel available
how455 |
Yes it is pm
Your number I can send pics it's been cut for radio unfortunately but in good shape other than that
bump
Hi there, Are the power window motors still available? Thanks.
Is the deck lid still available?
Deck lid is sold I may have some
More 1969 Parts coming this week I Will contact you if decklid Is any good
All Ac stuff has sold
Looking for a rear tag bracket/gas door, Thanks KC
