Old 05-19-2024, 12:41 PM
bhieb bhieb is offline
Question ceramic coating exhaust manifolds
Hi All,
I have a pair of 67 Ram Exhaust manifolds that I would like to get ceramic coated. (e.g. Jet hot). I live in the Detroit, MI area and wondered if anyone has done this and had good results? If so, what vendor did you use?
Brad
Old 05-19-2024, 05:44 PM
grivera's Avatar
grivera grivera is offline
Lots of people like the coatings but I had a bad experience with my LB manifolds. I bought them coated from RARE and within a year they were speckled in rust. I then had them blasted and used the POR 15 manifold coasting and that lasted much longer. Maybe they’ll give you a warranty for the work.
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
Old 05-19-2024, 05:56 PM
65madgoat's Avatar
Being quite a somewhat porous manifold surface it is best for your own hand applied coating versus a jet hot type or cerakote in most cases.
If you can find a good cerakote person, have them bake the manifolds first to get impurities out before they spray them.
Old 05-19-2024, 06:21 PM
Rachelsdad's Avatar
This thread has a good discussion of manifold coatings:
https://forums.maxperformanceinc.com...d.php?t=872899
As to the original question, I have no recommendations for places local to Detroit for ceramic coatings; sorry.
Lewis
Lewis Rosenthal
'63 Bonneville Convertible
'56 Safari
'82 Firebird SE
POCI #3596 (since 1978)
Old 05-31-2024, 08:49 PM
Hi grivera,
Thanks for this info. I wonder what type of ceramic coating the guys at RAM Air Restorations are using on their manifolds? I've seen some other postings indicating that Cerekote and or Jet Hot coatings are good, but you need to make sure the surface is super clean and the coatings are applied correctly. Not sure how much experience is required to get a good result.
Brad
Old 06-01-2024, 12:10 AM
Save your money and just prep and paint them with the POR-15 manifold paint.
Super expensive ceramic manifold coating with no real guarantee?
No thanks.
Old 06-01-2024, 09:42 AM
Hi Rachelsdad,
Thanks for this link to the other thread. Agreed, lots of good info there.
Brad
Old 06-01-2024, 09:43 AM
Smile
HI 65madgoat,
Thanks for the tip! Could be the difference between a coating job that lasts and one that doesn't.
Brad
Old 06-01-2024, 09:48 AM
No thanks.
Hi b-man,
Sounds like you've had good luck with the POR-15 manifold paint? I tried the Eastwood product and it lasted a couple years. Do you feel the POR-15 product is superior to the other hi-temp exhaust paint products out there?
A related question: what process and paint works best for engines? I've used regular rattle can engine paints which held up semi OK on parts that didn't get too hot, but the paint immediately burned off on the exhaust ports and started peeling around the thermostat housing. (I had a leak develop there). Wondering if I should have used a different paint product and possibly primed first?
Brad
