Old 05-19-2024, 08:33 PM
Tom Pugh Tom Pugh is offline
Default A6 reolacement compressor for '67 GTO
I'm looking at the attached A6 compressor to replace my existing Frigidare. The mfg. is Apco/Alma. It's advertised as new. Never heard of them. I assume they may be a Chinese company. Anyway, whats the thinking on replacement units? Also, I'll be running R12 from a supply I have.
https://www.ebay.com/itm/173092766990
Old 05-19-2024, 09:03 PM
gtospieg gtospieg is offline
If you're not concerned about looking factory(aluminum in color but same size) you might consider the "Pro6 Ten" aftermarket compressor. Much lighter and fits in place of the original. Also much less expensive($398 at Old Air Products).
Old 05-20-2024, 12:38 AM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Alma is an American company which has the original GM tooling to make the A6 compressor. They also use a lip seal instead of the original ceramic seal.
Nothing against the Proten aluminum compressor, but if you want an A6 the Alma is the way to go.
Also be advised Alma puts mineral oil into that compressor, so if you want to go with R-134a, you'll need to drain the oil and replace with PAG. OP said he's going to use R-12, so the oil the compressor comes with is fine.
The Following User Says Thank You to hgerhardt For This Useful Post:
Old 05-20-2024, 10:09 AM
good to know!
Old 05-23-2024, 07:43 PM
Cardo's Avatar
Cardo Cardo is offline
I have an Alma. Better than OEM considering they have the double lip seal. 4 years, not a drip, and ice cold.
"I know just enough to keep me here, but not enough to get me out"
Old 05-23-2024, 07:58 PM
good to know, I just bought one...
Old 02-04-2026, 01:30 PM
65madgoat's Avatar
Anyone know if the ALMA A6 compressor is still available anywhere?
