Old 05-22-2024, 11:02 AM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
Default More Tire and Wheel Questions
I have a specific size question. Is anyone running 15x8 with a 4.25 backspace on the front and rear on a 67? I’m wanting to run 255 60 rear and not sure on front yet.
I w read the 67 rear is 1” wider and the cars still has its correct rearend.
Old 05-22-2024, 01:48 PM
Tempest's Avatar
Tempest Tempest is offline
Here are some pics with 245/60 on the rear and 235/60 on the front
any wider on the front will be a problem as I have to be careful when turning into a driveway (for my car anyways)
ID:	634113   Click image for larger version
The Following User Says Thank You to Tempest For This Useful Post:
Old 05-22-2024, 05:25 PM
shifty's Avatar
shifty shifty is offline
Default Size ?
Hey Tempest. That's a good look.
Old 05-22-2024, 10:01 PM
ponchjoe's Avatar
Are these 4.25” backspace and 15x8?
Old 05-23-2024, 09:49 AM
Tempest's Avatar
Hey Ponchjoe,
I am not 100% sure, sorry, as I put them on so long ago, but I believe they are the 15x8's.
Hope the pics help
Old 05-27-2024, 11:50 AM
ponchjoe's Avatar
Still looking for help with a 67 using a 15x8 and 4.25 backspacing. Since the rear is 1” wider can you 255 60 without modifying the wheel lip?
Old 06-05-2024, 01:49 PM
grivera's Avatar
grivera grivera is offline
I’ll be in the same boat soon - thinking about buying this wheel/tire measurement tool:
https://claytonramstead.com/products/wheel-fitment-tool
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
