Old 05-22-2024, 09:02 PM
MidnightAuto's Avatar
MidnightAuto MidnightAuto is offline
Default Exhaust idle notes
Thought this might be helpful to those contemplating exhaust set up. My cars evolution.
Initial set up. ram air manifolds, 2.25 pipe, rattler mufflers. Tail pipes out rear. 60916 crower cam and 421 ho heads
https://youtu.be/usxSPokW0fs?feature=shared
Initial upgrade. Ram air manifolds, 2.25 pipes, dynomax ultraflows. Tail pipes side exhaust. Crower 60919 and kre d port heads.
https://youtu.be/fC30rf5CCM0?si=GgrHDyM9RYW4Uu7j
Most recent upgrade. Doug’s headers, 3 inch pipe, Sonoma’s ultraflows, x pipe, side tailpipe exit. 60919, kre d port. https://youtu.be/FlMAkukTOmE?feature=shared
Puttsing around the new exhaust is much deeper sounding and you can hear the cam
More at idle.
While there are some other winter upgrades making it hard to isolate- the car is running a lot faster with the new exhaust set up. I was torn in doing it- read a lot about headers vs rar manifolds. I had mandrel turn downs with the 2.25 too. But no question the new exhaust set up was worth it.
Old 05-22-2024, 09:47 PM
4dblnkldude's Avatar
All sound good!! But I like the third video best.
Old 05-22-2024, 11:04 PM
GtoFM's Avatar
GtoFM GtoFM is offline
My Mama told me nothin' good happens after midnight but Midnight, you changed that! Well done!
Old 05-23-2024, 04:24 AM
64speed's Avatar
64speed 64speed is offline
Your last setup is exact same as mine except mines run out the back. I love the sound!
The Following User Says Thank You to 64speed For This Useful Post:
Old 05-23-2024, 04:47 AM
64speed's Avatar
https://youtube.com/shorts/tFebY_Tq3...9mSAuHfpbht6N5
The Following 2 Users Say Thank You to 64speed For This Useful Post:
Old 05-23-2024, 08:16 AM
Thanks guys. 64 speed love your ride and yes sounds very similar. Great license plate too.!
Old 05-23-2024, 08:40 AM
Holeshot71's Avatar
Holeshot71 Holeshot71 is offline
X2 on the 3rd video! What are the mufflers? Sonoma’s ??
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55
'72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80
Old 05-23-2024, 10:05 AM
Ha. I saw that typo. Autocorrect converted “dynomax” into Sonoma. Go figure…
Old 05-23-2024, 11:56 AM
Wow, I wouldn't be tempted at the lights with that sound!
Old 05-23-2024, 12:47 PM
napster's Avatar
napster napster is offline
https://www.youtube.com/watch?v=GYMaDAeOO3g&t=98s
Old 05-23-2024, 07:58 PM
Very nice Napster! Sounds bigger than a 60919
Old 05-24-2024, 06:29 AM
Holeshot71's Avatar
Well at least it was close..
The Following User Says Thank You to Holeshot71 For This Useful Post:
Old 05-24-2024, 07:40 AM
pontiacs-r-us's Avatar
pontiacs-r-us pontiacs-r-us is offline
Sounds great…I’m a long time fan of dynomax mufflers… curious what size case are your ultra flows? I’m about to buy some for my 65… I’m a lil on fence whether to use welded case ultra flows,or there turbos …
Old 05-24-2024, 08:15 AM
They are the smaller case and are the welded version…
Old 05-24-2024, 01:02 PM
napster's Avatar
Thanks. Not bigger by much. XE288HR 236/242 @110LSA.
The Following User Says Thank You to napster For This Useful Post:
