Old 05-23-2024, 01:28 PM
Dauntless1971 Dauntless1971 is offline
Default When can you use 4.125 pistons on a 400 block?
I am considering using .005 oversize pistons on a block that appears to have very little wear on the cylinder walls. I have a dial bore indicator gauge, but l am not a machinist. Best I can tell the cylinder appears to be right at that measurement now. And forged pistons require 4 to 5 thousands clearance which can be done with honing?
Old 05-23-2024, 02:46 PM
Dragncar Dragncar is offline
You could hard block it. That requires a extra .002.
extra ring gap too.
Old 05-23-2024, 04:24 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Yes you can hone the cylinders for 4.125 pistons. It might not be enough to make the cylinder round with a torque plate.
Go fast, see Elvis!
Old 05-24-2024, 01:24 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
I had no problem running 4 1/8" pistons in my blown alky mini-puller, using a '67 400 block honed to 4.125". Turned 8,300 RPM on most runs. I heard a lot of "Didn't know Pontiac made a 401".
The Following User Says Thank You to Jack Gifford For This Useful Post:
Old 05-24-2024, 11:22 AM
extra ring gap too.
Is this filling the water jackets?
Old 05-24-2024, 12:46 PM
Tim Corcoran's Avatar
extra ring gap too.
This is interesting, does filling the block add heat to the top of the piston?
Tim Corcoran
Old 05-24-2024, 05:23 PM
Yes, filling them to the bottom of the water pump holes.
If you do it, get it done before you hone the block and its best to let it cure with a head-tq plate torqued down.
Old 05-24-2024, 05:45 PM
Yes, both Ross say to add .002 piston to wall, and Total Seal said to add .002 ring gap.
So I have .006 piston to wall and around .023 end gap.
Thing is, Dan said I might hear the pistons before it warms up but it sounds normal. And AWESOME too I might add.
Taking a day off today to get a 4 day weekend to work on my car.
Finish fuel pump, fuel cell install.
Finish new smaller brake booster and proportioning valve install along with a auxiliary vacuum pump for the brakes.
Put my PTC converter back in.
Install new 1350 front yoke.
And re install my headers I just got back from being coated. That will be a chore getting them in without scratching (700$ to coat) Think I will wrap them in blue painters tape first then take off.
And if I get around to it put in a Fantz by pass filter to go along with my K&P wire mesh oil filter. Made a fuel pump cover with 1/4" nipple to get the oil back in.
My old 455 I ran forever. Its .060 and I am planning on hard blocking it and running a .065 over piston and ridged hone with plate.
The extra .002 might be useful for me and might help the OPs situation too.
