Old 06-03-2024, 01:16 PM
soupman soupman is offline
Default Cracks in lifter valley area? Opinions
Hi
Was putting together my 433 with a set of 47 ported heads. Engine is a 9.7CR, 1969 400 block, with Icon forged pistons and stump puller cam. I have run this motor for over 3 years, no issues runs great, about 3000 miles.
While putting on the valley cover noticed these cracks or indentations. Hard to tell exactly. I do have a picture from the machine shop of the block and looks like those marks are there initially.
Should I try to fix or run it? I think if the cracks were bad the machinist would have said something about it. From my close look it appears they do not go all the way through the block, but hard to tell.
Thoughts?
ID:	634678   Click image for larger version
ID:	634679   Click image for larger version
ID:	634680   Click image for larger version
Old 06-03-2024, 01:28 PM
PAUL K's Avatar
PAUL K PAUL K is offline
It's hard to tell from the pictures. The ones in the back of the valley near the distributor are a non-issue. The one between the lifters and the head looks like a freeze crack. If it is a crack it should've shown with a Magnuflux test.
Go fast, see Elvis!
Old 06-03-2024, 01:29 PM
Casting flaw.
I’ve seen several block that were missing material in that exact spot at the back near the distributor due to an incomplete pour at the foundry.
The ones above the lifter bores don’t look like cracks, just the way it was cast.
Your machinist did check the block for cracks after cleaning and before machining, correct ?
If so then run it, there’s nothing wrong with your block.
The Following 2 Users Say Thank You to b-man For This Useful Post:
Old 06-03-2024, 02:42 PM
lust4speed's Avatar
Most blocks are really thin in the back area or do not have material there at all. I'll take the die grinder and remove the thin flashing just so I don't have to worry about it flaking off later.
Nice fat lifter bores and well centered - looks like no core shift at all.
Mick Batson
The Following User Says Thank You to lust4speed For This Useful Post:
Old 06-03-2024, 03:00 PM
spectramitch's Avatar
spectramitch spectramitch is offline
Looks a lot better than this one!
Old 06-03-2024, 03:48 PM
Paul- The one between the lifters and head is not a freeze crack, it’s a shadow from the pushrods. I was concerned about the back wall near the distributor.
The Following User Says Thank You to soupman For This Useful Post:
Old 06-03-2024, 04:25 PM
Formulas's Avatar
Formulas Formulas is offline
one time long ago i had some funky soft cam bearings had to pry the cam out,.... levered a big screwdriver in that back area against a cam lobe to push the cam foreward and out to replace the cam bearings and i broke a big thin chip out of that area freaked out at first then realized how thin and useless that particular area is and moved on without a broblem
........... The More You Follow The Herd The Less You Can Be In The Lead ..........
Old 06-03-2024, 05:06 PM
lust4speed's Avatar
Here's an early production 1970 block. The bottom piece was thick and not going anywhere so I left it in place.
Name:	1970 lifter valley.jpg
Mick Batson
Old 06-03-2024, 06:19 PM
steve25 steve25 is offline
I would rather have a hole there like in post #5! as I have had in many blocks then a casting flaw like that.
Old 06-03-2024, 07:13 PM
BILL BOWMAN1's Avatar
I’ve seen some really horrible lifter bore areas over the years, but never were they an issue.
The Following User Says Thank You to BILL BOWMAN1 For This Useful Post:
