Old 06-07-2024, 11:20 AM
ws6speedpaul ws6speedpaul is offline
Default 1974 Trans Am Formula Gage Cluster 100 MPH 6k TACH - Rally Gages
1974 Trans Am Formula Gage Cluster 160 MPH 6k TACH - Rally Gages
Includes all light bulbs & sockets, light pipe and flexible circuit.
Working when removed.
$600
Name:	1974 Firebird Trans Am Gage Cluster - Rally Gages_1C.jpg
ID:	634923   Click image for larger version
Name:	1974 Firebird Trans Am Gage Cluster - Rally Gages_2C.jpg
ID:	634924   Click image for larger version
Name:	1974 Firebird Trans Am Gage Cluster - Rally Gages_3C.jpg
ID:	634925   Click image for larger version
Name:	1974 Firebird Trans Am Gage Cluster - Rally Gages_4C.jpg
Old 06-07-2024, 11:58 AM
78w72 78w72 is offline
Wasnt 1974 still the 8K tach?
Old 06-07-2024, 01:48 PM
unruhjonny's Avatar
Between the images and description I am guessing Paul made a simple mistake on this listing;
It looks like he has used the printed circuit stamped date as the gauge pod date.
It also looks like he misread the speedo when he said it was a 160mph speedo - when it's actually a 100mph speedo (which also shows 160kph in blue)
The dual speedo readings (imperial & blue metric) first came in for 1975;
The 6k tach came in for 1977;
The speedo changed for 1979 - the secondary readings changed from blue to an orange-ish colour, and this was the first year that non-USA gauges had KPH as the predominant numbers (clocks were quartz movement this year too).
IIRC the printed circuits were the same for all 'Rally gauge w/tach' gauge pods for 1973-1979.
It looks to me as though this is a 1977/1978 gauge pod, with a replacement (from an older car) circuit board.
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
Old 06-08-2024, 09:33 AM
chuckies76ta's Avatar
https://forums.maxperformanceinc.com...d.php?t=533330
Just saying.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick.
Best so far 9.95@135 mph. 1.39 60 ft.
468 with KRE D-ports, Doug headers, 3" Exhaust
950 Quickfuel.
Old 06-10-2024, 12:24 PM
My apologies for the late reply.
Just want to agree with and thank unruhjonny!
He was spot-on with his assessment of the true circumstances regarding my initial posting, and contributing valuable information to his audience...thanks-a-bunch for clarifying things!
I would also like to thank bman for stepping in the way it should be done!
I will adjust the asking price to be more in-line with what it may be worth, but please reach out if you feel otherwise, thanks!
Old 06-10-2024, 12:27 PM
sorry bman, I meant to say "chuckies76ta"
Old 06-10-2024, 12:28 PM
Revised asking price is $260
Old 07-10-2024, 11:53 AM
$160
