Old 06-09-2024, 03:12 PM
cdrookie cdrookie is offline
Default Any tips for removing dried on buffing/polishing compound?
My painter got lazy with clean up after the job was done. I have some random spots of dried compound I can't get off. WD40 is slowly, and I mean slowly, removing it. I tried IPA/water mix, and wax to no avail. My next step is peanut butter. Is there a fast way to get this stuff off without harming the paint?
Old 06-09-2024, 05:29 PM
gary bennett's Avatar
gary bennett gary bennett is offline
Did you try any liquid polish?
DBANDGB
Old 06-09-2024, 07:07 PM
Rachelsdad's Avatar
First, I would never use WD40 (or any petroleum-based product) on a painted surface.
You have some options, depending upon where the buildup/residue is:
- Clay bar, lubricated with spray detailer
- Spray detailer alone, applied with a microfiber cloth
- Tar & grease remover, applied with a microfiber cloth (I prefer R-M 900 Pre-Kleano, but there are others - you need to get this from an auto paint supplier)
I've got some age-old stuff stuck in my trunk channel (just noticed today). In close quarters like that (finger width), the clay bar is not an option. I'll try detailer first, before I resort to wax & grease remover.
Good luck, and remember that dry compound will scratch like sand unless you keep it lubed.
You can use an orbital polisher, too (with polish), but again, because the compound is going to be abrasive, you want to take the *least* abrasive path to its removal.
GL HTH
Lewis
Lewis Rosenthal
'63 Bonneville Convertible
'56 Safari
'82 Firebird SE
POCI #3596 (since 1978)
Old 06-10-2024, 01:28 PM
Thanks for the replies guys
Old 06-11-2024, 12:53 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
A rag that's just damp with alcohol should work.
Old 06-11-2024, 09:01 AM
I tried that Jack and it didn't do anything. Peanut butter is working, but it's taking a little bit.
Old 06-11-2024, 12:55 PM
BILL BOWMAN1's Avatar
Lots of times using the exact same product will reactivate the old stuff. Not necessarily compound, but in general.
