Old 06-10-2024, 02:59 PM
Commissar Commissar is offline
Default Shifting Question - TH400
Hey everyone, I have a recently new to me 68 GTO that I bought and have been tinkering with now trying to get it right. The Engine is a 400 bored 0.030" over and sounds to be running strong attached to a TH400 his/hers hurst shifter.
My problem is when I am at WOT the shifts are very slow, like the car takes a few seconds to figure out what gear to go into (RPM according to hood tach is around 4-4500 when it starts thinking about shifting). Normal driving it shifts fine. Where do I start trying to troubleshoot this? When it does shift it shifts hard. I believe there is an 1800 stall in there. What is some other information that you all need to help me figure this out.
I have some other issues that I need to address as far as timing and carb setup, but those will be a different thread.
Old 06-10-2024, 04:01 PM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is offline
I'd start with a gauge and monitor your pressures. Sounds like a leak.
Old 06-11-2024, 05:36 PM
Where should I monitor from and what would I be looking for? I am pretty sure I can hear a vacuum leak under the hood, but havent been able to pintpoint it yet.
Old 06-11-2024, 09:31 PM
gtohurstjudge's Avatar
gtohurstjudge gtohurstjudge is offline
Fix your vacuum leak.....you have poor vacuum to the vacuum modulator on the right side
of the transmission. That could be causing your problem.
