Old 06-14-2024, 05:20 PM
redbird68's Avatar
redbird68 redbird68 is offline
Default 1-1/4" sway bar on 1969 GTO
Hello all!
I'm trying to install a spare 1-1/4" sway bar on my 69 goat.
Ordered links and bushing kit (PN 9.5172G), both poly, from Energy Suspension.
Bushings are greaseable which i thought was a good idea, but do not have to be.
The bushing bracket will not mount to the frame. OE has 2-9/16" center to center spacing; the new bracket has slots but the tightest hole spacing it will fit is 3-1/16".
They sell a Universal bracket as well, but the tightest spacing in the slots is still too wide at around 3".
https://www.energysuspensionparts.co...r-bushings.asp
I have read many old threads and i know many of you have made this swap.
How did you do it?
I talked with Energy Suspension guy and he had no ideas. Also called Ames and they do not appear to have a bracket that would work. I would go with rubber bushing if need be before i messed with drilling and tapping the frame.
How did you do it?
birds, goats and a few outliers
Old 06-14-2024, 05:45 PM
Socket head bolts. "D'ed" washers under head if you can fit it.
Old 06-14-2024, 05:52 PM
rt400 rt400 is offline
Default 1 1/4" sway bar
I used brackets and bushings off a late 70's Trans Am.
Old 06-14-2024, 06:02 PM
This.
Used the factory brackets and 12-point metric fasteners on two of my 1964 A-body Pontiacs, installing one is no different on a 1969. You can’t use regular hex head hardware as there’s not enough clearance.
I used urethane sway bar bushings on one car and a factory rubber bushings on the other so both types can be used with the factory sway bar brackets.
Old 06-14-2024, 07:41 PM
redbird68's Avatar
Thanks guys
I figured a set of original brackets/bushings from a TA would work...I measured the spacing of a bracket on a TA with the 1-1/4" bar and it appears to be 2-9/16" center to center, so would match the GTO frame holes. Problem is I do not have an extra set of brackets and cannot find them at the normal suppliers, except for the 'universal kit' that has the mounting holes spread too far apart. Socket head bolts would not help with the brackets i bought, you cannot even see the second bolt hole after you make the first one.
I'm still looking for aftermarket that fits or used OE brackets....if anyone has purchased aftermarket brackets/bushings that worked for this application please let me know
Thanks again
Old 06-14-2024, 07:54 PM
Place a parts wanted ad in the appropriate classified forum, someone out there has exactly what you need.
Old 06-14-2024, 07:56 PM
redbird68's Avatar
That is a great idea!
Will do.
Thank you
Old 06-15-2024, 09:55 AM
redbird68's Avatar
I ended up ordering Energy Suspension 9.5113G, found on amazon (free delivery is cool)
This summit link shows the specs:
https://www.summitracing.com/parts/ens-9-5113g
the specs show that the bracket will work for 2-9/16" bolt centers
will report back when i get them
Old 06-15-2024, 09:56 AM
redbird68's Avatar
Old 06-20-2024, 08:11 AM
redbird68's Avatar
Update:
the 9-5113G bracket fit to the holes on the frame. Had to dremel the slots a little to get the slots aligned to frame holes, then ground down one side of a washer to fit it up against the bulge in the bracket. Regular Grade 5 hex bolts then fit fine. One thread hole in frame stripped, was able to grab a nut with hemostats and stick it through hole in frame, then screwed the bolt up into it. Worked fine. If other bolts fail in future might need rivet nuts.
Thanks everyone.
Old 06-20-2024, 05:00 PM
locomotivebreath's Avatar
locomotivebreath locomotivebreath is offline
How’s the handling on the GTO - did it make a big improvement ? Did you replace a 1 inch bar ?
When I wore a younger man's clothes
Old 06-21-2024, 07:55 AM
redbird68's Avatar
I am anxious to find out! Hopefully this weekend, will report back.
Front brake hoses needed replacing so doing that today if they show up.
The sway bar I removed was an OE 1" bar with rubber bushings and links. The rubber was not in good shape but I have seen worse.
I also just installed bilstein B6 shocks at all 4 corners so the impact of the 1-1/4 bar will be mixed with the impact from the new shocks. Old shocks were delcos that were fairly easy to collapse but again i have seen worse. PO had installed boxed trailing arms and a rear sway bar. PO also appears to have replaced all 4 springs which i believe to be stock replacements.
Looking forward to a test drive. Car was a little 'floaty' compared to my F bodies so hopefully this firms it up.
Will let you know.
Old 07-05-2024, 01:42 PM
redbird68's Avatar
Finally got the goat on the road this morning. Handling is much better, no more 'float', car is firm in turns and just seems firmer over all but not to the teeth rattling stage. Over all a great improvement....the bilsteins and the 1-1/4" sway bar definitely helped. I think either one by themselves would have been a noticeable improvement.
Now i need a tighter ratio steering gearbox.......
Old 07-05-2024, 02:39 PM
redbird68's Avatar
Installed pics
The larger bar was bent just a little bit different than original 1" bar and the pass side bracket was not aligned with the frame holes when it was snugged up on the bar. Slotted the bushing bracket with dremel, than cut the foot off an old firebird sway bar bracket and used it a a washer to spread load across the bushing bracket. This is the hole that stripped so there is a Gr5 nut up inside the frame, allowing me to tighten it good.
I will keep an eye on it but should be good I think.
Thanks all for your help.
ID:	636321   Click image for larger version
ID:	636322   Click image for larger version
