Old 06-14-2024, 08:02 PM
redbird68's Avatar
redbird68 redbird68 is offline
Default 1-1/4" sway bar mounting brackets
Hello
I'm looking for a pair of original brackets to attach the bar to the frame
putting the bar on a GTO, spacing of mounting holes needs to be 2-9/16" center to center, or close to that, to match the threaded holes in the frame. I believe the brackets from a bird will work if they held the 1-1/4" bar.
Thank you
Bill
birds, goats and a few outliers
Old 06-14-2024, 11:55 PM
Formula403 Formula403 is offline
The most common size you'll find from F-bodies, especially the later years. New, used and repro, not hard to find.
Old 06-15-2024, 10:09 AM
78w72 78w72 is offline
I should have some of these brackets, will check later today & PM you.
Old 06-16-2024, 11:00 AM
PM sent
Old 06-16-2024, 12:12 PM
redbird68's Avatar
I ended up ordering some energy suspension brackets. assuming they will fit i no longer have need for any OE brackets
thanks
The Following User Says Thank You to redbird68 For This Useful Post:
