Old 06-28-2024, 10:43 AM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
Default Power antenna mounting and wire harness securement...
My '79 was originally equipped with the UP6 and U83 Tri-band CB combo, which includes the power antenna on the fender, and it still works but it's missing some parts.
My power antenna unit can just be turned by hand if you reach in and twist it, which I'm pretty sure it's not supposed to, as it is supposed to be secured in place by bracketry. I found the part numbers for the brackets in the service manual and obviously can't find them anywhere.
Also, after scouring the 1979 service manual supplement, I also see that there is a "clip" that secures the power and radio wires coming from the antenna to the fender liner, and a "strap" that bundles those wires together coming from firewall grommet so that they are secured and not just hanging loose.
Right now I just have the wires bundled together with a zip tie, because before they were just hanging loose and hitting the fender liner. It was annoying while I was driving the car because you could hear the tapping, but I would obviously like the original mounts/clips/and brackets to be put back on the car as when it was new.
Does anybody else have this option on their T/A, and could you maybe take some photos of how your antenna is secured as well as how the wiring is routed and what these "clips" and "straps" look like, assuming it's all original?
I'm not counting on any luck with this, but I'd appreciate it!
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
Old 06-28-2024, 12:23 PM
My 74 has a power antenna in the trunk but I assumed it was aftermarket.
Old 07-17-2024, 12:48 PM
TAKerry TAKerry is offline
I am just about to put this back together on my TATA. I can post pics of the mounting bracket if you want, just let me know. Unfortunately I only have one bracket but it looks like it could be reproduced easily enough. According to the service manual there is a plastic clip (looks like the same one that holds the headlight harness to the core support) that mounts to the inner fender. The diagram says 'drilled in the existing dimple'.
Old 08-06-2024, 09:43 PM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
I believe the left front fender mounted power antenna was standard equipment on all...79 10th anny's.......80 Indy Pace cars and 81 Recaro Daytona Pacecars....FWIW...
Old 08-07-2024, 09:42 AM
burd burd is offline
I think I still have the brkt, when I go to Dayton at the end of the month I’ll be going through all my parts. If I have it, do you need one?
