77 Pontiac lemans with original a 350 oldsmobile. I yanked that out and found a 403 at my local engine mechanic. He rebuilt it but it took some time for me to stab the engine in. Plus $$$ obviously. In the time it took to try get parts and everything. It locked itself. So it's stuck. Will keep you posted!!
Rip engine #2 Sent from my SM-S536DL using Tapatalk |
Maye some kind of obstruction?
A well oiled fresh build would take some serious neglect to be unable to be turned. Try the flywheel end.
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
| The Following User Says Thank You to 694.1 For This Useful Post: | ||
Even if the engine is stuck due to rust, it likely can be saturated with some penetrant for a week or so, then broken free by applying pressure on the flywheel side, as already suggested.
You could also get a inexpensive bore scope to look into each cylinder to see what you're dealing with too. Unless the engine was filled with water, I doubt all is lost. I've seen some engines brought back that were filled with water, that run no different than one that hasn't been frozen up ever.
A little bit of update the machanic that rebuilt the engine suggested the same thing. Or also that it may be the torque converter, not stab in correctly, so I have to pull the engine back out and see if I have the third click. Here's hoping!
