Is there another trans x-member other than stock that will give more room for 3" pipes ???
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s |
The way the G-Force mounts are fabricated, it creates some extra room. Not a ton, you're mostly dealing with the floor boards and getting everything tucked up against those.
Have you considered oval tubing?
| The Following User Says Thank You to JLMounce For This Useful Post: | ||
