Old 08-03-2024, 04:53 PM
skinny035 skinny035 is offline
Default 65 GTO a/c fan shroud indent?
I have a gap between my metal shroud and my radiator. I was just at a car show and saw a 65 with a/c and there was no gap. However, I noticed there was an indent in his metal shroud so that the radiator bracket didn't interfere with the shroud. Should there be an indent for the bracket? I have attached a pic of his 65.
Old 09-30-2024, 11:11 PM
elefantrider's Avatar
elefantrider elefantrider is offline
Something looks off here. Doesn't look like the correct shroud.
Old 10-01-2024, 02:36 AM
gto4ben gto4ben is offline
The '67 Assembly Manual shows a 9420222 nut placed beteen the shroud and the bracket. I suspect '65 did something similar.
Name:	Radiatot Shroud Assy DWG.jpg
ID:	640791   Click image for larger version
ID:	640792   Click image for larger version
Old 10-01-2024, 09:59 AM
Definately has a square nut on the bracket. But my '65 shroud does not have an indentation.
Old 11-30-2024, 01:35 PM
tallrandyb's Avatar
tallrandyb tallrandyb is offline
'65 with factory AC and steel shroud: I have no indent like that but definitely a nut between the bracket and the shroud.
