Old 08-13-2024, 10:45 AM
ebartone ebartone is offline
Default Driveline Advice
Hi everyone, I am new to this forum!
I have a very nice 1968 GTO that I built an engine for mostly for the strip. Its engine dynode at 500 HO and 600 Ft lbs. at 5,200 and 4,200 RPM. The car is otherwise stock, and I'm nervous about breaking the driveline. Doug's headers and stockish dual exhaust although I'm thinking about cut outs. It has a 10 bolt 3.36 Aubern Posi in it, and I am running MT street / strip tires. I just put in the Posi last year.
I'm thinking that if I replace the driveshaft, U joints, Pinion and Ring, and Axles I'd be in good shape, rather than buying a 12 bolt and replacing the expensive Aubern, plus those other things too. Does this make sense?
Thanks!
Old 08-13-2024, 11:01 AM
Elarson's Avatar
Elarson Elarson is offline
That makes sense. Based on my limited experience long ago with a Trans Am, 12 bolt rearend and stock driveshaft & U-joints.....putting on 9" slicks immediately revealed the stock axles to be the weakest link.
Breaking a u-joint can cause the driveshaft to tear up the floor of the car, so getting better parts there is good insurance.
Hope this helps,
Eric
Old 08-13-2024, 11:06 AM
Thanks! Any advice on Sources / brands for:
1) U Joints
2) Drive Shaft
3) Axle
4) Ring / Pinion
5) Other Support Components?
I'll likely have the same company that installed my Aubern install all of this at the same time.
Thanks,
Old 08-13-2024, 11:26 AM
JLBIII JLBIII is offline
Are you running a manual or auto trans?
Have you tried looking for a used rear already setup?
Are you doing any of the work yourself and what area are you located in?
Old 08-13-2024, 11:30 AM
Thanks, I should have mentioned TH400 Transmission, I'm in SE Michigan, and I can do U Joints of course and Driveshaft, but when it comes to working inside the pumpkin, I'll have the same company that put in my Aubern do that. I'd just like to bring the parts I choose to them.
Old 08-13-2024, 11:31 AM
No I have not tried looking for anything used.
Old 08-13-2024, 01:56 PM
Elarson's Avatar
1) U Joints
2) Drive Shaft
3) Axle
4) Ring / Pinion
Thanks,
My first choice is always Strange. Mark Williams and Moser have good stuff too.
Eric
Old 08-13-2024, 04:02 PM
Dragncar Dragncar is offline
You will tear that 10 bolt posi up with slicks.
I broke 9" Trac Locks and Detroit Posi units with a 455 that was just a little more powerful than yours.
Overbuild your rear end. 9" maybe. Those lightweight Dana 60s are a good choice these days. Look closer to stock too.
The Following 3 Users Say Thank You to Dragncar For This Useful Post:
Old 08-13-2024, 04:34 PM
Some opinions on 8.2 rear end upgrades in the link below, most would recommend replacing it with something stronger especially now that you’re looking to dig in and spend money on strengthening your 8.2:
https://forums.maxperformanceinc.com...d.php?t=871811
Once you realize that you’re going to be 2k+ into your 8.2 you might regret not putting those funds towards another stronger rear end. Just because you have a new posi unit in your 8.2 doesn’t mean you need to continue using it.
The 8.2 has a weak housing with poor pinion support. The corporate 10-bolt 8.5 is almost as strong as a 12-bolt and well-worth considering. Money spent on the 8.2 is money wasted unless it’s for a concourse restoration in my opinion.
Old 08-13-2024, 07:49 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
When I ran Top Stock in the old NMCA John McWhirter, one of the original Comp Cams owners) had a 66 tripower Olds 442 stick car that had been a drag car it's whole life. It was usually faster than the rest of us in the class but he often broke the 8.2 with slicks and a 4 speed, so you had a shot of winning class if you drew him!
I agree with Bart a 8.5 10 bolt or a 12 bolt is a good start and good U joints and driveshaft.
FWIW my 78 TA has a 8.5 10 bolt that has run a lot of passes in the 11s and even high 10s with slicks and Eaton Posi and stock 28 spline axles. Lakewood U joints and a rebalanced stock driveshaft. It now has a 30 spline posi and Moser 30 splines. My MW 3.5" drive shaft in my IA/Camaro is a very nice piece but you have to measure the way they want you to.
Skip Fix
Old 08-13-2024, 08:46 PM
Tim Corcoran's Avatar
If I were you I'd put a 12 bolt in there with some steel axles. The cast iron axles and the 10 bolt rear are the weak link. If this is just a street car you should be OK as is but if you start racing it regular at the track then you may find out how much the 10 bolt and cast iron axles will take.
Tim Corcoran
Old 08-14-2024, 08:01 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Get a 9", Dana 60, or 12 bolt. Your 10 bolt will have a short life with 600 ft lbs
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
The Following User Says Thank You to OCMDGTO For This Useful Post:
Old 08-14-2024, 10:15 AM
Hey everyone, thank you for the advice - I see in the thread linked there was a huge discussion on this already - I didn't mean to confuse things, I'll keep reading that also. I'm trying to find a source for the complete 12 bolt "package" and keep it under say $3K or so if possible, if anyone has advice. Thanks again!
Old 08-14-2024, 03:00 PM
spectramitch's Avatar
spectramitch spectramitch is offline
I am in SE Michigan and was going to take my race car to Drive Train Specialists in Warren for a new driveshaft and replace my pinion yoke to 1350. I was told that their custom drive shafts are made by CCI Drive line.
Old 08-14-2024, 05:33 PM
Would The Auburn posse that fits in my 8.2 work on a 10 inch? I just don’t know if the ring and pinion would fit? Maybe obviously not?
Old 08-15-2024, 01:58 AM
Nothing inside your 8.2 will work inside another upgrade rear axle unit , except if you were to find a Nodular Iron 8.2.
But that's a small step as far as upgrade , and you'll overspend entirely on bang for buck.
If you buy anyone's used equipment - not being highly versed on rear assemblies - you might get burned on stuff that has already been beaten up in the past. Lot of smooth talking racers out there trying to sell beat up stuff to newbies.
I think you are going to want more gear ratio also. Probably a better torque convertor
Will you be racing 1/8 mile or 1/4 mile - or both ?
Keep your 8.2 3.36 in case racing gets too expensive (breaking stuff / more upgrades / project creep) and you decide to go back to street driving only.
Old 08-15-2024, 07:17 AM
I appreciate the advice, thank you everybody. I am looking at the suggested vendors for a 12 bolt assembly, and I will have my local gear company that did my Posi install it. I can’t seem to find an 8.5 new assembly, only 12 bolt But again, thank you. I guess everybody has to start learning somewhere. By the way, I definitely have been running the quarter-mile. Thanks again.
Old 08-15-2024, 08:04 AM
Half-Inch Stud's Avatar
Yes do that. And when done price-compare to a Strange Dana60 (which has great TQ margins).
Old 08-15-2024, 08:42 AM
Funny, you mention that, because I have done that, and see a very significant price difference! Knowing what I’m trying to accomplish, do you think the strength of that set up is comparable to a 8.5, or a 12 bolt?
Old 08-15-2024, 08:44 AM
https://www.strangeengineering.net/p...g-mounts.html/
