Old 08-19-2024, 08:16 PM
Tim Corcoran's Avatar
Default Plug for heater outlet on timing cover
What are you guys using to plug the heater outlet on timing cover?
Tim Corcoran
Old 08-19-2024, 08:35 PM
yahooskidoo's Avatar
yahooskidoo yahooskidoo is offline
Default Plugged
$60 shipped.
Old 08-19-2024, 08:57 PM
grivera's Avatar
grivera grivera is offline
I believe this covered in the Jim Hands How to Build a HP Pontiac V8…IIRC, it’s a 3/8 pipe plug?
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
Old 08-19-2024, 09:02 PM
Carefully tap it for a 3/8 NPT pipe plug. Don’t run the tap too deep, test your plug a few times during the process.
The casting is thin so don’t over tighten the plug.
No need to cut the hose nipple off of the cover, just thread it for the plug. This of course assumes the nipple isn’t corroded and thin.
Old 08-19-2024, 09:37 PM
Thanks, I need to look and see if I have a 3/8 pipe tap
Tim Corcoran
Old 08-19-2024, 10:04 PM
grivera's Avatar
Use RTV on the plugs threads
Will Rivera
