I think most, if not all of us are aware that they used 2 different bushings (round or oval) on the rear bushing on the front lower control arm. My 66 GTO has oval bushings.
My question is, is there any rhyme or reason a particular car would get one vs. the other? Is it year specific, plant specific, or completely random? Just curious.... Importsmasher
Scott Baggiore 66 GTO convertible 389/4 speed (parents bought new) 73 Firebird Formula 400/4 speed 74 GTO 455/4 speed 74 Grand Am Last edited by importsmasher; 08-27-2024 at 05:59 PM. Reason: Clarification |
Ooh. good one.
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
Common sense says which, direction the torque is forcing the axis (pivot bolt) needs more rubber to cushion the force as well as wear longer.
If you've replaced as many bushings over 5 decades as I have, they always break down on one side. The round bushings will first compress, then wear away the broken down rubber until the center sleeve is loose in the rubber, and the bond breaks down. The longer it is driven like this, the more play happens to the pivot joint, until there is just the sleeve bouncing around inside of the outer shell. Just a guess that possibly the more severe the usage (stick shift cars) that the engineers would opt for a bushing with more rubber for isolation, and longevity. Years ago, before there were urethane bushings racers used to hammer finishing nails into the bushings to stiffen the joint to stop wheel hop, this actually made the durometer readings increase on the rubber bushings, and stopped the wheel hop. The rubber hardness, and thickness plays a big role in how the joint acts under severe stress. On front suspension, the bushings also figure into spring rates because of their resistance to movement. Certain suspension options may use the bushings to fine tune the end spring rates. Just some observations over the years of working on mostly GM cars, and building race cars over the years.
I would say random.
Depending on what they had on hand they’d use on the assembly line. I’ve heard of cars built with both types, one on each side.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
