Old 09-04-2024, 02:59 PM
PontiacHO PontiacHO is offline
Default Factory Valley Pan - RTV Or Gasket?
What is typically used on a factory valley pan these days? RTV or a gasket?
Thanks?
Old 09-04-2024, 03:03 PM
indymanjoe's Avatar
RTV is the only thing i have had luck with.
I am the Thread Killer!
Old 09-04-2024, 03:25 PM
Sirrotica's Avatar
In 1973 GM/Pontiac was one of the first manufacturers to use RTV as a gasket replacement. That application was for the Pontiac valley cover gasket.
I always bought GM gaskets from the local Pontiac dealer as it was usually cheaper, and you didn't end up with a bunch of unused gaskets that you threw in a drawer. or set on a shelf. In 1973 I went in and asked for valve cover gaskets, and a valley cover gasket to repair a 69 GTO I had recently purchased. The parts man handed me 2 valve cover gaskets, and a tube of black RTV with a GM part number on it. I of course inquired where my valley cover gasket was, the parts man explained that GM had superseded the RTV for valley cover gaskets.
Long story short, I used the RTV. and haven't used a valley cover gasket since. It's kind of like the chevy guys never use end rubber seals for their intake gaskets anymore. The RTV is superior to the gaskets IMO, so I'll keep using it.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 09-04-2024, 04:06 PM
tooski tooski is offline
I used rtv on my 461. Then I had a lifter ticker. I changed it in car. It was a bear removing the valley pan. I reinstalled it with the cork gasket sealed with petroleum jelly. Then another lifter failed. (Then replaced them all.) Glad I didn't have to fight with rtv again.
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
The Following User Says Thank You to tooski For This Useful Post:
Old 09-04-2024, 04:15 PM
grivera's Avatar
grivera grivera is offline
I use a gasket for the same reason - definitely don’t want to distort the flange during removal.
Will Rivera
Old 09-04-2024, 04:20 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
I’m a gaskets guy, it comes apart easier and less clean up if needed
Old 09-04-2024, 04:38 PM
Prying off a valley pan that’s been glued down with the Right Stuff or similar without a gasket will usually cause you to bend the crap out of the pan getting it off, ruining it in some cases.
The gasket is far more forgiving in that respect and seals just fine using the proper method.
Old 09-04-2024, 04:58 PM
steve25 steve25 is offline
When your working on your daily ride and it’s Sunday night at 10:30 and your mocking up how your intake sits on your milled heads and it does not with all the gaskets and pan in place then you do what needs to be done.
IE remove the pan gasket and use RTV to get that last needed ,035” of clearance. :-)
Old 09-04-2024, 05:12 PM
Sirrotica's Avatar
There is absolutely no need to use right stuff, as I said, GM substituted black RTV, and later on GMS red RTV. I never use right stuff because it is really difficult to remove.
I've taken dozens off in dealerships, as well as my own, and my customers. I guess if you use hammers for tools then you might destroy a valley pan. I've never bent one, but I guess if you use right stuff, you could possible bend one.
I've used RTV on all of my race engines, and if anything, a race engine is going to come apart much more often than a streetcar is.
In the late 70s and 80s GM used RTV on every engine they made, on all the valve covers and oil pans, not right stuff. Never had one iota of trouble removing engine sheet metal from any of them............
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 09-04-2024, 05:15 PM
And regret glueing it down when you try to pull the pan later on to investigate some issue….
Old 09-04-2024, 05:26 PM
I am so glad I amuse you, but I Never regretted it!
With a new single edge blade or a carpet knife with and new blade and and standard size screwdriver I would have it popped off in 30 seconds with no damage.
You just need to know what your doing.
Old 09-04-2024, 05:42 PM
Okay then the next time you’re ready to do a 30 second removal of a valley pan we’ll be here to see the video of you performing that.
So we can all learn how it’s done.
Fair enough?
Old 09-04-2024, 06:07 PM
Sure thing.
Old 09-04-2024, 06:17 PM
East East is offline
Default Suum Cuique
I used a gasket all of the times that I installed the valley pan. If there comes a time when I cannot get a gasket, I will use RTV.
To each his own.
Que Sera Sera
Old 09-04-2024, 06:42 PM
The reason I asked…
Getting all my parts ordered. It appears that whomever did the engine work on my Firebird more than likely used nothing but RTV because they ****ily squoosed it out everywhere making a real ugly mess. Same for the thermostat housing. It all fits with how the “romp em stomp em” big arse cam was chosen for an otherwise stock engine, torque converter, rear end, and exhaust. If it sounds “tough”…..then it is. Hand me that next tube of Permatex. Probably a kid. We’ve all been there I reckon.
Old 09-04-2024, 07:23 PM
Formulas's Avatar
Formulas Formulas is offline
I have done it both ways... sometimes you need to get the intake off of the cover so gasket omission works in that case with just RTV.
Sometimes i skim coat the gasket with RTV.
A bent cover lip can easily be tapped with a mallet to get back to normal its not the end of the world, done it many times and you would never know it
if it looks like it was removed with a grenade you would be lacking the skills required in the first place
........... The More You Follow The Herd The Less You Can Be In The Lead ..........
Old 09-05-2024, 06:28 AM
Formulajones's Avatar
Formulajones Formulajones is online now
I'm a gasket guy. Just makes life easier later on.
https://youtu.be/XqEydRRRwqE
Old 09-05-2024, 08:21 AM
chiphead's Avatar
chiphead chiphead is offline
I had trouble with the bottom edge of the RPM intake flanges hitting the valley pan. I had to clearance the intake and use RTV on the valley pan to get enough clearance for the intake to clear. I used a thin stream of black oil proof RTV, and it sealed up very nice. It will take some careful work to get it apart again, but at least it's leak free in the meantime. I wish I could use the gasket, but sometimes it just won't fit in there.
Old 09-05-2024, 08:44 AM
mgarblik mgarblik is offline
I use a combination of the methods described in this thread. #1: I DO NOT use "Right Stuff", rock hard RTV on anything, especially sheet metal parts. Although it may seal, it is nearly impossible to remove and bends and destroys thin sheet metal, like valve covers, oil pans, Chevy front covers and such. I have also had it crack and break thin castings like rear seal carriers on LS engines and various flimsy thin castings on import engines. Even castings with factory pry points for removal. It creates many more problems than it cures. On Pontiac valley covers, this is how I seal them. I install the cover dry with no gasket or sealer first. Then I use a shot filled plastic hammer and carefully massage the flange all the way around to get a consistent gap or fit. Then I use some 3M weatherstrip adhesive, a small amount to stick the cork gasket to the valley pan so it stays put. Next I put a very thin coat of regular RTV, Permatex Ultra Black is nice, but I use VALCO. I spread it with my finger, very thin, .015", .020". I put a small blob in the 4 corners. Next I lower the cover in place. Finally, I put a small amount of RTY under the head of the 2 attaching bolts and tighten then up. I haven't had a valley cover leak in decades.
I hate oil leaks and this method works well for me. FelPro says my method is improper and you should never put RTV on a cork gasket. But it's hard to argue with success.
The Following 3 Users Say Thank You to mgarblik For This Useful Post:
Old 09-05-2024, 09:25 AM
rolling money pits's Avatar
rolling money pits rolling money pits is offline
Would the “valve cover gasket” method work/apply in this instance? Adhering gasket to valley pan, then on block side use grease or whatever, to seal it.
I’ve read about that, in the past never applied it, was a careful RTV guy, and of course had weeping here and there.
Or, is the valley pan a different animal in that there’s multiple parts/seams - block and heads - it seals, unlike the VC which has a nice uniform surface it rests on?
costs too much
