Old 09-11-2024, 06:33 PM
65madgoat's Avatar
Default 1970 to 1973 Trans Am - FRONT SWAY BAR BRACKET
What are you all using for replacement OEM style sway front sway bar brackets on early 2nd gen Trans Ams?
Don't want to go Energy poly kit, so where to buy a stock looking bracket and 1.25" bar bushings?
I think AMES has something but not as a kit. Seems like some brackets don't work with some rubber bushings.
Then Inline Tube for some reason lists 2 different style bracket kits:
https://www.ebay.com/itm/204923154687?
https://www.ebay.com/itm/166944927488?
Thanks.
Old 09-12-2024, 10:30 AM
Singleton Singleton is offline
14073310 is the original part number for the bracket. There's a couple on ebay
66 GTO, 495, M22, Strange S-60 w/4.10
Sold new at Royal Pontiac (Dealer# 07-679)
70 Formula 400/auto
The Following User Says Thank You to Singleton For This Useful Post:
Old 09-12-2024, 01:08 PM
65madgoat's Avatar
Thanks. Confirmed what OEM looks like too
Old 09-12-2024, 01:47 PM
I believe 472118 is the bushing
70 Formula 400/auto
The Following 2 Users Say Thank You to Singleton For This Useful Post:
Old 09-12-2024, 03:56 PM
fbody_mike's Avatar
fbody_mike fbody_mike is offline
Hopefully my memory is not failing me, but on my 72 with a 1.25" front bar I went to the wrecking yard and pulled the brackets from a 2000 Escalade, then went to Autozone and bought bushings for a 2000 Escalade with a 31.8mm front bar. Even has the little rubber part that sticks out for the dimple in the frame. I did this because I got tired of the poly squeaks.
Again, if my memory is right, it did not matter what size bar the donor Escalade had, the brackets were the same.
I built it one piece at a time and it cost me more than a dime.
The Following User Says Thank You to fbody_mike For This Useful Post:
Old 09-13-2024, 10:28 AM
fbody_mike's Avatar
Ok after thinking about this I think I got the brackets off a caprice. But the rubber was over the counter 2000 escalade.
