Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 09-12-2024, 01:26 PM
68bobcat 68bobcat is offline
Default high compression heads and some tools for sale
Items for sale:
All prices are plus shipping from Rochester, New York 14618. Tools are all used but in good shape.
1. Rebuilt high compression heads. #62 1969 large valve 72cc chamber heads. Screw in stud bosses. New Ferrea valves and springs installed for .600” travel. Never bolted onto a block since the rebuild this year. VERY Mild porting and surfacing. Date codes are both J078 (September 1968). Rocker arms and studs are not included. Painted correct Pontiac blue. $1400.00
2. Rebuilt high compression heads. #46 1969 small valve 75cc chamber heads. Press in studs. Fresh: magged & rebuilt stock and then bagged and on a shelf since 2007. Never bolted on. New intake valves. Date codes are L198 and L188. Unmolested from a 1969 428 wreck with less than 30K miles. Stock valve job. High torque low rpm heads are ideal for big heavy cars or towing. $400.00
3. Elgin Cam E-576-S New old stock (NOS). For large displacement, high torque low rpm Pontiac and Buick and Olds engines. $50.00
4. 428 Crank Nodular p/n 9782789. Unmolested from a 1969 428 wreck with less than 30K miles. $300.00 Prefer not to ship.
5. Valve spring compressor tool. p/n CF-11 Heavy duty. Clark-Feather $40.00
6. H-gauge S&K tools p/n T-0030-A pump clearance gauge. Used $50.00
7. Pinion depth gauge Central Tools p/n 6470 Used $200.00
8. Pinion depth checker T&D tools p/n MT5100 (new p/n 11001) $200.00
Pictures coming as soon as I can figure the upload process.
Steve
Old 09-12-2024, 03:17 PM
pics of heads and crank
ID:	639868   Click image for larger version
ID:	639869   Click image for larger version
ID:	639870   Click image for larger version
ID:	639871   Click image for larger version
Old 09-12-2024, 03:23 PM
cam and CF-11
ID:	639873   Click image for larger version
ID:	639875   Click image for larger version
Old 09-12-2024, 03:26 PM
Pinion depth gauge and checker. Make offer for both together. Additional pictures available in larger format.
ID:	639877   Click image for larger version
Old 09-12-2024, 03:40 PM
H-gauge pictures
ID:	639881   Click image for larger version
ID:	639882   Click image for larger version
Old 09-13-2024, 08:23 AM
PontiacHO PontiacHO is offline
Sent you a PM
Old 09-14-2024, 04:48 PM
Cam is sold. Thank you PY forums.
