Did a search and didn't find what I was looking for.
I've got those rubber caps blocking the heater hose nipples on my 400. The one on the timing cover has begun weeping coolant. Is there another option to block off the nipples, besides those clamp-on caps?
The timing cover is easy. You can tap it for 3/8 NPT. The one in the head can be plugged like the opposite side head. But can be difficult task when the engine it together and in the car.
Those rubber caps are made of crap rubber so check them often!
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
| The Following User Says Thank You to Skip Fix For This Useful Post: | ||
I used those a long time ago when I removed the A/C suitcase from the engine compartment. It may have been my imagination but I always felt like it made my engine run hotter.
Ugly way but much better if you can’t do it the way Paul suggests would be to find both a 3/4” and 5/8” stainless bolt that has about an inch of shank on it and saw off the threaded portion.
Cut short lengths of heater hose that’s not going to rot the second you look away from it and just hose clamp everything to plug it off. I tried using those rubber caps about 30 years ago and they were rotted within a few miles so they’ve always been crap. Don’t use them even for a short time.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
When the former owner of my '73 paid to get it running again, they bypassed the leaking heater core and connected the two hoses using something like this...
https://www.ebay.com/itm/402531725861
So long, farewell. |
caps
suck I change mine every year..lol
1970 firebird, 468, e heads, |
i got some really nice caps off amazon. i don't recall the name, but its VERY well made.
it was twice as expensive and just for one, but its a nice piece silicone cap instead of that dorman crap.... the dormans hardly lasted a year for me..... the silicone one has been on for over a decade and still looks so nice i want to say mine might have been AEM or something like that, and a nice blue/black color too something like this if i am not mistaken https://www.amazon.com/Partuto-Unive...%2C314&sr=8-18 |
thats what i did when i used to dorman ones
now i use the silicone style and so much better see post above |
I used the reducer to connect the heater hoses together and it works very well. James Q
James Quayhagen 1963 Bonneville Safari - Nocturne Blue, 4-speed - SOLD |
| The Following User Says Thank You to jamesq For This Useful Post: | ||
Bart's short lengths of hose is the best solution and will last for years. Had a friend that had the caps rot out before the project was able to hit the street. Worse of the worse Chinese rubber.
Careful drilling and tapping the timing cover housing. The heater hose nipple is thin and the stock cast aluminum cannot take much pressure at all before splitting. Every drop of water that leaves the passenger side head at the rear is coolant not available to travel forward and cool the head. Pontiac did it correct on the old engines and pulled it off the front crossover but the bean counters won and to save some 3' of heater hose moved the hose feed to the rear of the passenger side head. I've read that some people are worried about how plugging it affects cooling but just remind them that the driver's side head does fine with being capped off.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
Short chunk of hose. Cut the treads off a bolt and use 2 hose clamps with a little RTV under the head of the bolt.
if you guys notice the dorman caps do not have the integral fiber reinforcement some of the ones linked DO..
Dorkman should be used for painting and storage
........... The More You Follow The Herd The Less You Can Be In The Lead .......... |
Make plugs from alum, leave the hoses on. Looks factory.
