Old 09-17-2024, 02:59 PM
i82much's Avatar
i82much i82much is offline
Default installing transfer slot restrictors
After installing transfer slot restrictors into a 4150 style carb, should I be able to push a drill bit through the restrictor all the way into the body of the carb so I can see the drill bit by looking down into the primaries?
Thought I read somewhere you could drill too far into the main body and I'm worried I may have done so ...
Old 09-17-2024, 06:25 PM
Formulas's Avatar
Formulas Formulas is offline
If you drilled where i think you did, straight across from lower IFR's in towards main body into primary bore? yeah not good
........... The More You Follow The Herd The Less You Can Be In The Lead ..........
Old 09-17-2024, 06:31 PM
steve25 steve25 is online now
Are you seeing brass chips or aluminum from the drilling you did?
