Old 09-23-2024, 05:21 PM
nh68gto's Avatar
nh68gto nh68gto is offline
Question Rally temp gauge
Hey all
Converted to rally a while back. Only gauge not working correctly is the water temp. Has new delco nail head sender. As car warms up it does respond but runs up to pegged hot. Still runny triple gauge until I trust it. But that gauge shows normal running temps.
Ideas ?
Ty.
Send it! It’s going home on a trailer.
Old 11-28-2024, 03:49 AM
Squidward's Avatar
I'll throw a shot at it.
Disconnect your wire to the sender. Take resistance readings at the sender with a multimeter starting with engine cold, and periodically as it heats. Try to see where the temp vs resistance chart goes off the rails, or if it tracks as it's supposed to.
At 70*, resistance should run between 600-700 ohms. As temp goes up, resistance goes down, where you might have 50 or less ohms resistance at 250*.
Some have used variable resistors to check the proper operation of the gauge.
I saw something on team Chevelle where 68 seems to be an odd year. Maybe your sender is not right for your gauges.
https://www.chevelles.com/threads/co...-unit.1084088/
Old 11-28-2024, 08:29 PM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is offline
The modern “new” delco temp senders won’t work with ‘68 gauges as you've discovered. Find a 1513371 “nailhead” or 6402383 “spade” if you can. Or else try one from Lectric Limited, as they claim to have compatible ones. You could also check with Pete Serio as he might have something.
The Following User Says Thank You to 65 Lamnas For This Useful Post:
Old 11-29-2024, 03:05 AM
Carl S Carl S is offline
I'm thinking you might have a misprint in your first part number, I think it should be 1513321 maybe?
1966 Strato Chief 427 4 Speed 45,000 miles
1966 Grande Parisienne 396 4 Speed Factory Air (1 of 23)
Old 11-29-2024, 03:58 AM
gto4ben gto4ben is offline
I checked the temperature-resistance curve of both of my spade and nail head types. At ambient to hot, they track reasonably close. Your sender should have similar characteristics.
ID:	643664   Click image for larger version
Name:	Temp vs Resistance.jpg
Old 11-29-2024, 10:49 AM
65 Lamnas's Avatar
Yeppers....thanks!
