Old 09-27-2024, 05:54 PM
nh68gto's Avatar
nh68gto nh68gto is offline
Question 69 heater A/c vacuum lines
Finally getting the controls to work
Got things plugged in. I’m not getting switch from door operation.
I do have an extra all black line that I’m not sure of its placement.
Is ported vacuum on a Holley enough to run the doors?
Fan speed work except Hi, and cold to hot is working.
Send it! It’s going home on a trailer.
Old 09-27-2024, 07:07 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
You need direct vacuum at all times. Not ported. If your fan is not working on high it could be a blown or missing fuse in the feed from alternator or it could be the high speed relay that's mounted on the firewall.
The Following User Says Thank You to Bruce Meyer For This Useful Post:
Old 09-27-2024, 08:26 PM
nh68gto's Avatar
Ok if I have time tomorrow will try and get manifold vacuum source. Probably gonna have to T off something.
Old 09-28-2024, 05:48 PM
nh68gto's Avatar
Got em working. Manifold vacuum and everything working as it should.
