Old 10-02-2024, 04:41 PM
dv657172's Avatar
dv657172 dv657172 is offline
Default Header recommendation?
100% dedicated 65 GTO drag car with 68 Pontiac 400 (461) and 68 #16 heads
Car runs 7.58 in the eigth which should put it just a bit under 12.0 I would think.
Car currently has Hedman straight through headers 1.75" primary tubes into 3" collectors (#35010 I think, on car when purchased) with header extensions
Ran the car on a dyno yesterday and first recommendation was to change to a header with a merge collector.
Any thoughts on this advice and/or recommendations?
DV
Old 10-02-2024, 06:12 PM
Steve C. Steve C. is offline
These might be of interest....
https://www.motortrend.com/how-to/cams-carbs/
https://www.speed-talk.com/forum/viewtopic.php?t=59881
Old information here:
Old 10-03-2024, 12:23 PM
Ken MacNicol's Avatar
Ken MacNicol Ken MacNicol is offline
Save your money for some other upgrades
The Following 2 Users Say Thank You to Ken MacNicol For This Useful Post:
Old 10-03-2024, 01:11 PM
This.
You have a car running 12 seconds flat/high-11s with headers that are not a bad size for your combo.
Spending about a grand for a nicer set with perhaps bigger tubes and a merged collector won’t buy you any huge gains if at all.
If the car picks up maybe a tenth in the quarter would that time and money be worth it?
Old 10-03-2024, 02:03 PM
dv657172's Avatar
Thanks guys for your thoughts I really appreciate it. There are likely some other things that might make a better improvement for the $ in the suspension
The Following User Says Thank You to dv657172 For This Useful Post:
Old 10-03-2024, 05:12 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Figure there are cars with 600 HP running 1 7/8 headers! My RAIV 400 ran faster with 1 3/4 than 2" headers!
Skip Fix
The Following 2 Users Say Thank You to Skip Fix For This Useful Post:
Old 10-03-2024, 06:45 PM
I can recall reading where Floyd Hand was running 1-5/8” primary tube headers and running into the mid-11s with a 455 in his ‘66 or ‘67 Le Mans.
Old 10-21-2024, 05:08 PM
77 TRASHCAN's Avatar
A good friend of mine had a 72 GTO, 455 HO. He was a small time local area racer. May have only raced at Cordova, Illinois track 82 and earlier. He moved to Oklahoma in 1982. Never raced the car here, had plans to, though.
Anyhoo
He made connections with other stock racers in his part of the country. Back then cam choices were very strict, not much of a choice. The racers with money to spend started using cams that had extremely fast opening and closing ramps. Some referd to them as "square" lobed cams. I'm not sure if his engine had one of those.
Back to headers>>
My buddies name is/was Richard Allen. He passed in 2018, Parkinsons claimed him. He was a medic In Viet Nam for one year. I would fearfully guess that any Viet Nam vets still might have Parkinsons. 3 men on the small street in Muscatine Iowa, where he moved back to in 2017 have it...
Headers. Richard knew Rock Running, He had a car similar to Richards. He had a set of 1-5/8 inch tube HO headers he wasn't using. They were Headers by Ed. He and Rock swapped some parts. Richard said those headers were hell to install. I know, we (I). put new header gaskets on it, to prep it to sell. He said they DID help. he said he picked up 1-2 tenths.
All this may be meaningless. Nobody runs a cam anwheree near a square lobe 068 in any of their street engines. Just throwing it out.
Thanks for reading!!!
Jeff
Shut it off
Shut it off
