Old 10-04-2024, 06:30 PM
SD73's Avatar
SD73 SD73 is offline
Default Clip Pic
I have posting looking for one of these, but no bites yet. Does anyone have a pic of this clip? If I can get some length and width measurements along with the hole size I may be able to fabricate it out of another clip I have.
Thanks,
SD73
Old 10-05-2024, 01:33 AM
rolling money pits's Avatar
rolling money pits rolling money pits is offline
Based on the factory pix you posted, that clip looks a lot like firewall harness clips, just mounted upside down.
I don’t recall their specific application, but if you look for engine compartment harness clips, I think you may find something either identical, or a reasonable facsimile.
costs too much
Old 10-05-2024, 08:04 AM
Held for Ransom's Avatar
It's not like the drawing. Google (or search here) 478007 clip. Being it was used on many years, it should be easy to find one.
So long, farewell.
Old 10-05-2024, 08:47 AM
Formulas's Avatar
Formulas Formulas is offline
Going from recollection i think its coated spring material open face the harness got pushed in then a simple pinch closed the clip... i will see if i can find one
........... The More You Follow The Herd The Less You Can Be In The Lead ..........
Old 10-05-2024, 08:57 AM
Searched that # and this came up
https://forums.maxperformanceinc.com...d.php?t=875291
Clip you’re referring to?
costs too much
The Following User Says Thank You to rolling money pits For This Useful Post:
Old 10-05-2024, 11:42 AM
SD73's Avatar
Thanks guys for the clarification! It turns out I had a spare and now it's in place as it should be.
