Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 10-12-2024, 10:39 PM
imposter's Avatar
imposter imposter is offline
Default wanted centerline auto drags
looking for a pair of centerline auto drags 5x5 pattern 15x7 or 15x8
The Following User Says Thank You to imposter For This Useful Post:
Old 09-03-2025, 12:47 AM
imposter's Avatar
bump
Old 09-03-2025, 10:06 AM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
In case you don't find any used...
I bought a new AD set from CL, I then got the satin middle polished and they look great.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
Old 09-03-2025, 10:09 AM
imposter's Avatar
sorry whats a AD set
Old 09-03-2025, 10:14 AM
GOAT8U2's Avatar
Centerline still sells the Auto Drags, AD.
They have limited back spacing but they still offer them.
Old 09-03-2025, 10:38 AM
imposter's Avatar
sorry brain froze on that AD comment however they do'nt sell any new 5x5 bolt patterned wheels
Old 09-03-2025, 11:05 AM
If you or a friend have access to a CNC mill you can modify a Ford or GM set to 5 on 5 bolt pattern.
