Prev Previous Post   Next Post Next
Old 10-17-2024, 01:02 AM
Sprocket's Avatar
Sprocket Sprocket is offline
Default Parts for Sale at the Pontiac Southern Nationals this weekend
I will have the following parts for sale at the Pontiac Southern Nationals this coming Saturday in Frisco, Texas. Feel free to stop by and buy, buy, buy!
Bilstein Shocks front & rear - B6 Performance '68-'72 GM A-body, '69-'72 GP/Monte Carlo New in box $300
BMR Suspension Front upper & lower DOM control arms '68-'72 GM A-body, '69-'72 GP/Monte Carlo New in box $600
BMR Suspension Rear upper DOM control arms & axle housing bushings '68-'72 GM A-body, '69-'72 GP/Monte Carlo New in packaging $100
BMR Suspension Rear control arm reinforcement braces '68-'72 GM A-body, '69-'72 GP/Monte Carlo New $100
BMR Suspension Coil springs - front & rear '68-'72 GM A-body, '69-'72 GP/Monte Carlo New in box $200
BMR Suspension Rear sway bar - 1" solid '64-'72 GM A-body, '69-'72 GP/Monte Carlo New in packaging $120
UMI Performance Front sway bar - 1.25" solid '64-'72 GM A-body, '69-'72 GP/Monte Carlo Installed and removed $200
Tanks Inc Fuel tank straps & hardware '68-'72 GM A-body, '69-'72 GP/Monte Carlo New in packaging $30
Holley Street HP 950 polished carburetor Universal 4150 square bore Used for engine break in $500
Holley Street Dominator intake manifold w/separated water neck Pontiac 326-455 Used $150
Doug Nash - Warrior Intake manifold w/separated water neck Pontiac 326-455 Used $300
CompCams Ultra Gold aluminum roller rockers - 1.52 ratio Pontiac 326-455 Installed never ran $400
Lunati Retro-fit hydraulic roller lifters Pontiac 326-455 Installed never ran $400
MSD Pro-Billet Ready-to-Run distributor w/vacuum advance Pontiac 326-455 Used for engine break in $400
PowerMaster XS Torque mini starter Pontiac 326-455 Used for engine break in $150
Ames Performance 68-72 GTO Ram Air d-port exhaust manifolds Pontiac 326-455 Used $260
GM 455 crankshaft Pontiac 455 Used $80
GM 12-bolt axle assembly - Eaton posi, 3.42, forged axles '64-'72 GM A-body, '69-'72 GP/Monte Carlo Used <10,000 miles $1,500
'70 GP Model J
467 Butler ported Edelbrock D-ports
Torker II intake with Holley Sniper 2
CompCams 236/242 hydraulic roller
Tribal Tubes tri-y headers full 3" stainless exhaust
TH400, 3.50 9" CurrieTrac, 245/35-20 Front, 275/35-20 Rear
