Old 10-27-2024, 09:05 AM
PLongen PLongen is offline
Default 63 Lemans Dash Blinker Problem
My dash indicator only flashes with the left on nothing on the right, all other lights are fine. What could this be?
Thank you,
Pat
Old 10-28-2024, 08:34 AM
Radman's Avatar
Radman Radman is offline
If you still have incandescent bulbs, check that both front and back indicator lamps are flashing. If you have switched to LED you will just have to live with it. It would be the direction of current flow.
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
Old 10-28-2024, 08:43 AM
Right hand front and rear lights flash but dash does not only on right side. Might be switch under dash. No LED
Old 10-31-2024, 01:46 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
For the Tempest Lemans cars in 1963 the turn-signal switch is located inside of the steering column. It is a one year only switch and it just fits the small body car.
Those '63 switches do go bad, & they are hard to find.
Peter Serio
Owner, Precision Pontiac
Old 05-30-2025, 09:23 PM
Sanduners's Avatar
Sanduners Sanduners is offline
For those with a 63 and the turn signal switch is good but the cancel doesn't work to turn off the signal I have a fix. Only need to remove the steering wheel. I've sold about 80 of these 3D printed cancel cams.
The Following User Says Thank You to Sanduners For This Useful Post:
Old 06-12-2025, 07:16 AM
It was the led bulb. problem fixed.
