Old 11-29-2024, 10:00 AM
mysticmissle's Avatar
Default Aluminum front motor plate
Looking to maybe change my
Front set up currently have the all
Pontiac plate that uses the lower 4
Timing cover bolts for location
Likely
Will Stay w that style but looking for an aluminum one if available
Checked With KRE already nothing available
Old 11-29-2024, 12:26 PM
chuckies76ta's Avatar
There seems to be a few mid-plates that are aluminum available. I would just be curious if the plates front and back would flex if both were aluminum. I have just a front motor plate from All Pontiac which is working out really well. I guess you could always take yours to a fab shop and they certainly could make you one.
https://www.swracecars.com/products/...nt-motor-plate
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick.
Best so far 9.95@135 mph. 1.39 60 ft.
468 with KRE D-ports, Doug headers, 3" Exhaust
950 Quickfuel.
Old 11-29-2024, 02:10 PM
I don't want that style, I need room for hot side pipes at some point thank you though
The Following User Says Thank You to mysticmissle For This Useful Post:
Old 11-29-2024, 02:13 PM
73 TRANSAM 73 TRANSAM is offline
Default front motor plate
I made my own using a 1/4" thick 6061 aluminum plate. I made it so I can utilize a down and forward turbo headers.
