Old 12-03-2024, 04:28 PM
spectramitch's Avatar
spectramitch spectramitch is offline
Default Plastic Fuel Cell Lifespan
I have a plastic 16 gallon fuel cell in my trunk. I am sure it is at least 15 years old. Is there an "expiration" for the age of these plastic tanks? It seems to be in pretty good shape, doesn't look cracked or anything. I am running 110 leaded race fuel
Old 12-04-2024, 08:16 AM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
Unless it is exposed to a lot of sunlight i would expect
It to last quite a while longer. Inspect for
Cracks
Or leaks around the fittings maybe chafing around the straps
But if properly installed and supported you should
Be good. I have heard of foam
Deteriorating but I have not had an issue, but to be fair my foam
Was removed from
The cell (switch to e85) prior to its 15th birthday
Old 12-04-2024, 02:36 PM
Ken MacNicol's Avatar
Ken MacNicol Ken MacNicol is offline
Mine has been in my car since 88' , I did have to remove the foam about 5 years ago though .
Old 12-05-2024, 01:37 PM
73LeMans's Avatar
73LeMans 73LeMans is offline
I ran mine in my cold dark trunk for 20 years, no issue. No expiration I'm aware of either, so long as it meets the criteria mentioned above.
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....and 2023....and 2024.....and 2025.....who am I kidding? there will be no 9s with this engine!
>>My 73 Build thread
Old 12-11-2024, 12:13 AM
Probird's Avatar
Probird Probird is offline
Mine has been in the car since 1978. 46 years and no problems. I removed the foam to run methanol a long time ago though. It’s not really needed.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
2024 Chief of the Pontiacs
