Old 12-10-2024, 07:46 PM
joes455 joes455 is offline
Default Main bearing clearance
Here are the clearances I got ,arp studs torqued with arp ultra lube 130lbs rear 110lb 1-4
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 12-10-2024, 07:47 PM
Oh 400 stroker
Old 12-10-2024, 07:54 PM
54nomore's Avatar
54nomore 54nomore is offline
Those clearances are so next year! Sorry, I had to.
Old 12-10-2024, 08:09 PM
steve25 steve25 is offline
If you just switched to studs then the clearance is secondary to the line bore being straight.
This needs to be checked first with a checking bar.
Old 12-10-2024, 08:44 PM
track73 track73 is offline
If it were mine i'd buy some .00 1 under bearings and put half on the uppers.
1979 Trans Am WS-6 .030 455 zero decked
flat pistons
96 heads with SS valves
041 cam with Rhoads lifters 1.65 rockers
RPM rods
800 Cliffs Q Jet on Holley Street Dominator
ST-10 4 speed (3.42 first)
w 2.73 rear gear
__________________________________________________ _______________________________
469th TFS Korat Thailand 1968-69 F-4E Muzzle 2
Old 12-11-2024, 12:41 AM
chiphead's Avatar
chiphead chiphead is offline
For a 3" main engine it's loose, assuming measurements are correct. Were these measurements taken with plastiguess or a dial bore gauge?
When i built my 4" stroker, I shot for .0025-.00275" on all the mains. I think the rear main came out about .003. I was using a Scat crank with the journals on the small side and the main bores were on the larger side of spec. So I had to use FM 4040M1 bearings, they are .001" tighter than STD.
The Following User Says Thank You to chiphead For This Useful Post:
Old 12-11-2024, 01:16 AM
Verdoro 68's Avatar
That seems loose to me based on my minimal experience. My mains are all around .0025 with the largest around .0027. I'd try some different bearings.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 12-11-2024, 08:51 AM
AG's Avatar
AG AG is offline
You could also have your bearings coated to decrease the clearances. I have done that before and Calico's thick coating decreased the clearance by 0.0007-0.0008". But as Steve said, I would first check your main bores without bearings to check for concentricity and size. I have put main studs in before and they changed the size of the main bore compared to factory bolts and I ended up getting the main line done.
Old 12-11-2024, 10:59 AM
Gary H's Avatar
Gary H Gary H is offline
IMO, too loose. I'd shoot for .0025 - .003
The Following User Says Thank You to Gary H For This Useful Post:
Old 12-11-2024, 11:38 AM
All measurements were done with a Fowler bore gage crank was measured with starlet mic ,I'll be getting it linehoned regardless .The vertical clearance was excessive due to crank being worn by .0005.Should the clearance get bigger or smaller as measuring closer it gets to parting line ?Also when checking saddle bores should they be perfectly round ?
Old 12-11-2024, 12:26 PM
HWYSTR455's Avatar
I used to mock it up with bearings and crank, light film of oil, torque to value, rotate crank a few times, remove the crank, and take measurements w bearings in place.
That will give you the most accurate measurements.
Is the workshop very cold? Temp-wise?
Old 12-11-2024, 12:39 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I had to use King 0.001 larger halves to get mine just right plain STD were too tight. Mixing the 2 sets got me right on.
Skip Fix
Old 12-11-2024, 01:54 PM
chiphead's Avatar
It's been my experience that the bores themselves should be fairly round until you get right at the parting line. The parting line taper is in the bearing inserts themselves. The clearance should be tightest 90* to the parting line then get looser by about .0005 as you approach the parting line. This is to prevent the bearing crush causing a high spot at the parting line. The taper can change depending on the bearing crush, the bearing type, torque value, etc etc. Rod bearings can have more parting line taper because of how the rod bearing bore can distort during operation.
The Following 2 Users Say Thank You to chiphead For This Useful Post:
Old 12-11-2024, 06:37 PM
HWYSTR455's Avatar
Yes. And that's why I mock it up first, remove crank, torque caps to value, and measure with the bearings in place. (After crush)
That should provide readings as it would be in use. Or as close as possible.
The lock/locating tabs on the bearings is an area that will not 'crush' much, or not as much as the rest of the shell.
Old gearhead machinist suggested I do it this way a long time ago, and continue to do so. Try it both ways and take readings and see what you get. Will make a believer out of most.
Old 12-11-2024, 07:36 PM
Skip that's how I got those clearances is with bearings installed.Just noted today that my bore gauge has spec sheet showing is calibrated to + - .0005.Anyways got out the plastic gauge and front bearing showed 2.75
The Following User Says Thank You to joes455 For This Useful Post:
Old 12-13-2024, 04:02 PM
charlie66's Avatar
Id run those clearances ...
My Half AN Injun.....
Old 12-17-2024, 03:08 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Take it from a stroker guy that got .00495 on his mains and 8psi hot old pressure and yet the builder is going to be fighting me in court about it, those initial clearances of .0035 are great to him. LOL
New engine is .0028, great oil pressure.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
The Following User Says Thank You to GOAT8U2 For This Useful Post:
Old 12-18-2024, 12:10 PM
67Fbird's Avatar
67Fbird 67Fbird is offline
even without a spec sheet. Basic rule of da thumb-----between .0007 and.001/per 1" dia holds true for the TOP end of pressurized oil clearance fit. On a 3.500" main....your good. On a 3" main your OK...not the shoot for number but OK
Old 12-19-2024, 07:13 PM
Did you mic your bearings before setting them? Rule of thumb: clean and mic the bearings, mic the main journals then set the bearings and measure the bore diameter. Fowler is a pretty good basic bore gauge, but invest in a quality bore gauge graduated in .0001 instead of .0005.
Dr. Thomas Sowell
Old 12-20-2024, 03:22 PM
charlie66's Avatar
I almost had the same clearance numbers . #1) 3.0 #2) 3.5 #3) 3.4 #4) 3.6 #5) 3.4
Been driving it all summer . Hot in gear oil pressure is 38 psi Cursing at 2000 rpm is 80psi.. I use 20/50 VR1 for oil..
