Old 01-30-2025, 06:33 PM
GearHd6 GearHd6 is offline
Default 1964 389 waterpump plate?
Is this correct? I feel like there should be another plate in there?
Old 01-31-2025, 08:16 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
There's another plate the goes with it, I tried down loading a photo but it wouldn't let me. Go to inline tube and search 65 pontiac water pump plate.
Old 01-31-2025, 09:46 PM
Scott Thelander's Avatar
And you need a water pump w cast impeller
Many 64 got a cast and a steel divider
If you want a sweet original pair
I have them for 55 shipped
Old 02-01-2025, 10:40 AM
burd burd is offline
Ames has the plates. In stainless to I believe. I git a nOS GM on in one of my tubs. Too cold to pull it out for a pic though.
Old 02-01-2025, 02:47 PM
george kujanski's Avatar
http://forums.maxperformanceinc.com/...d.php?t=411256
Go to response #17
George
Old 02-22-2025, 09:21 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
this is a 65 , I think 64 is the same
Old 02-23-2025, 08:11 PM
Ames is a 2 piece set for 1963-68 water pumps with 8 bolts.
Old 02-24-2025, 02:06 AM
I personally have seen 3 different styles
for
the 64-68 divider plates....
I think I still have all 3 styles
early they were cast aluminum
then went to tin with a round hole on rear plate
then the impeller change and they went to the notched hole on rear plate
the early cast plate does not fit in the 68 cover nor the 67 covers I have
I have no info on repro plates...
