The 2bbl (7043062) on our '74 Ventura 350 has an off idle stumble that I've been trying to resolve. It's really pronounced when the engine is cold, so much that it will backfire or stall sometimes, but it's always there even when at operating temp. I figured it was going lean, so I welded in an O2 bung this afternoon and used my wideband to see what was going on.
The mixture is spiking to 15.5-17ish when I step on the pedal from idle (~14.0 AFR). It will cruise ok once you get past that initial spike and otherwise the mixture seems ok throughout the range. I've gone through several accelerator pumps trying to diagnose this. I can see that it's getting a good squirt of fuel immediately so I don't think that's the problem. I'm wondering if I need bigger jets. It's got 54s in it now which I believe are from the factory. I know most folks have 4bbls, but figured I'd ask since these are similar to the center carb of a tri power.
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5 TSP converter - Moser 3.55 Truetrac (build thread | walk around) '74 Ventura 350 '69 AMC Javelin SST |
Does this carb have a power piston for enrichment like a QJ? If so, is it possible you have a metering rod sitting too low in the jet or could benefit from a lighter spring?
Any chance richening the idle mixture could help? |
It has a power valve in the bottom of the fuel bowl between the jets that's spring loaded. No metering rods like a QJ.
I had the idle mixture richer (13.4) before I plugged in the 02 sensor and leaned it out.
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5 TSP converter - Moser 3.55 Truetrac (build thread | walk around) '74 Ventura 350 '69 AMC Javelin SST Last edited by Verdoro 68; 02-02-2025 at 12:37 AM. |
Assuming the power valve is vacuum-actuated, is there any chance your vacuum has changed? For example, did your brake work introduce a vacuum leak?
It crossed my mind, but I haven’t found any vacuum leaks yet. I supposed one way to test is to disconnect and cap all the vacuum ports on the carb and see if it runs better.
If it's like a QJ, the vacuum holds off the enrichment, correct?
If so, a vac leak wouldn't explain a lack of enrichment, would it? Although if the vac was so low that the valve never closed and you compensated by enriching the idle, then maybe?? I'd say get a vacuum gauge before assuming?? Or maybe it's all about your vacuum advance and the legendary "carb problem is an electrical issue" has snuck under your hood? Might be worth verifying your vacuum advance can with a mighty vac and a timing light? |
It pulls a steady 19 inches of vacuum at idle, but I haven't left a gauge plugged in while we're driving to see what's going on. I picked up a new vacuum advance anticipating this potentially being a distributor issue. Will dig in more tomorrow.
What if anything else was done to the carb or the motor before this problem started up.
Was the carb sitting for months? If so then the power valve in the bottom of the fuel bowl might be hanging up due to crap getting in the fuel bowl vent or simply from failed broken down jelled up gas.
I would:
1. Check inlet valve for correct style and size. 2. Check float settings. 3. Open idle tubes to .034". 4. Open idle needle holes to .075". HTH |
Does the power valve rod move freely?
I've had to un-stake some to polish the bore and piston.
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
| The Following User Says Thank You to 77 TRASHCAN For This Useful Post: | ||
It’s hard to say when this started. The car sat for 6 years before we got it. We did a bunch of things to get it roadworthy.
I went through and thoroughly cleaned the carb including removing the power valve and cleaning all passages. It moves free. I ensured the float is within spec. I tried two different needle and seats. Getting fuel to the bowl doesn’t seem to be an issue. It just doesn’t get enough to the engine when transitioning from idle. What will opening the idle tubes and idle needle holes do?
It will give better control of the idle needles, strong idle and more even transition to low-speed.
I forgot to mention what post 10 did.
That spring loaded rod must move without hesitation also, not just the valve in the fuel bowl. That passage to each booster under the valve could be gummed up also . And also that whole booster pump discharge cluster could have been put together with the wrong gaskets because as I recall the rebuild kits supply two different ones.
I did some checking and and your 2GC carburetor 7043062 was used in both '73 and '74 and had 7002654 jets (54) like you said and is for A, F, X automatic transmission cars Non-California.
The vacuum plumbing is rather complicated and there are many possible points for vacuum leaks. In addition, hot and cold temp switches can fail or their wiring breaks. With my daughter's '71 LeMans with the 350 2GC and A/T, it had an off idle stumble from several causes. The vacuum motor in the air cleaner had torn it's diaphragm and needed replacing. The vacuum modulator hose at the transmission came off. The distributor vacuum solenoid plastic nipples had cracks and the plunger did a poor job of sealing when activated. It got replaced. I'd also check if your EGR diaphragm isn't leaking and it's got a good gasket seal and the vapor canister valving is in good shape. Check your radio fuse since it's used to power the TCS. Check the throttle shaft for excessive play. The 2GC base is cast iron and usually doesn't experience wear like the quadrajets so I doubt it needs throttle bushings; however, I have seen cracks in the cast iron along the throttle shaft, perhaps from uneven tightening onto the manifold. On my 455 with a '71 quadrajet, it had an off-idle stumble. Replacing the accelerator pump didn't cure it and no vacuum leaks were discovered. Crazy as it sounds, the cure was to adjust the mixture screws using the shop manual's lean drop procedure. I included those section's from the '74 shop manual for you. Your 17:1 AFR lean measurement just off idle is a clue that the accelerator pump shot isn't enough to compensate. (Too much oxygen, not enough fuel combining with it in the burn). The idle and off-idle carb slots need to provide more fuel. I'd try the lean drop adjustment to find the spot where there do. Back in the '70's, inspection stations allowed as much as 4% CO and 400ppm HC for '74. Using your wideband sensor, set the mixture at idle to a hair above 13 at the factory idle speed and see if that improves the off idle stumble. |
| The Following 3 Users Say Thank You to gto4ben For This Useful Post: | ||
Forgot to mention that I removed all the TCS stuff on the car and have disconnected the EGR.
It’s my understanding that if the EGR does not function then the motor will have a lean condition unless steps are taken to correct for having the EGR disconnected.
An EGR not working in itself will not cause a lean condition unless the diaphragm is torn, which is not likely even on a 50 year old valve. Much more likely that in this case the carb is too lean for whatever reason.
Jeff |
| The Following User Says Thank You to geeteeohguy For This Useful Post: | ||
Sounds like the EGR situation may not be helping. Th valve is still installed, I just unhooked the vacuum to it. The thermostat is switch is long gone and all the vacuum lines were rotted. With all the TCS stuff gone, the vacuum advance is now hooked up directly to a ported source on the carb.
I just tested the EGR and it holds vacuum. The vacuum advance does not so there’s a likely culprit.
| The Following User Says Thank You to Verdoro 68 For This Useful Post: | ||
New vacuum advance didn't fully fix it, but it's better than it was. I am getting a full 36 degrees of advance now, too. I ran it with and without the EGR connected to vacuum. It actually seems to run a little better/richer with the EGR disconnected.
I'll take the carb apart again, remove the power valve and make sure everything's clean under there, then I'll try the idle adjustment procedure Ben mentioned above.
Spiking even higher at tip-in really sounds like an accelerator pump issue--but I am biased. I had perpetual problems with the accelerator pump on Mom's '77 Nova 305 with 2GV. I eventually installed a Cliff Ruggles-supplied accelerator pump which seems to have cured that problem. Quote:
ANY misfire for ANY reason will cause an O2 sensor to report a false-lean condition. Plugged passage on the power valve? Failed vacuum advance; advance connected to ported vacuum? Weak ignition coil? Failed pickup coil wires on an HEI distributor? |
