| Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
I have a forklift attachment that I use at work on the Bobcat and tractor. The previous guy had somehow bent one of the forks. This causes problems for obvious reasons.
I’d like to straighten out the bent one, but I’m afraid heating it with an oxy/acetylene torch might make it brittle and therefore dangerous. Any ideas? Thanks!
‘63 LeMans- ‘69 400 w/ original transaxle. 2.69 gears. ‘55 Catalina ‘62 Mercury Meteor-all original, bought new by my grandfather 71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs.-now my sons ride |
Safety. Check Google for an answer
| The Following 3 Users Say Thank You to sdbob For This Useful Post: | ||
With zero experience straightening forks, I'll jump in anyway.
I suggest you NOT heat it, as it is probably made of a heat-treated, tough alloy like 4140. Heating enough to help bend it will weaken by annealing, or worse, could embrittle if the heat is high enough. To make it "tough" typically involves tempering back from a quenched, brittle state.... in other words, a controlled heat-treating process that will be difficult to reproduce with a torch, along with being "localized" The fact that it bent without breaking shows the fork has significant ductility. Like a coat hanger, you should be able to just bend it back with low risk for it breaking and without decreasing its strength. Net: I'd try and find a way to straighten it without heat. Will obviously involve some big forces or big levers, but you have a big machine behind the forks. Ask the guy that bent it how it happened and try to replicate the scenario in reverse... Good luck! Mike |
| The Following 3 Users Say Thank You to Shiny For This Useful Post: | ||
![]() Good info though. We have a full size Kubota “farm” tractor , which is what we usually use it on. I’m sure we could figure out some way to give it the beans to bend it back.
| The Following User Says Thank You to 67drake For This Useful Post: | ||
Straighten it in a Press.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
When we have bent forks it worked best to find something heavy to pry against to bend it back with it on the loader yet. Forks are generally heat treated, heating them again will weaken them.
That is a relatively light duty fork to bend like it did, probably made of 1050 or 1060 steel. |
| The Following User Says Thank You to Jay S For This Useful Post: | ||
Former fork lift tech here, DO NOT HEAT THEM, you will weaken them for sure because of the heat treat. You'll have to bend them cold such as on a press, but they will still not have the same strength as they did before they were bent.
Ideally if someone such as myself would inspect the truck the bent fork would be condemned until it was replaced. Straightening them isn't considered as a proper repair because the units safe lifting capacity would be compromised, thus compromising safety, leaving a liability. In the real world things sometimes fall outside of the ideal circumstances, and people elect to save money and open themselves to a bit of increased liability after weighing out the probability of all factors. I can't say I haven't done this myself. |
Maybe buy a new fork.
Or send it to a heavy equipment repair outfit and let them handle it. Don’t hurt yourself trying to save your company a few dollars.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
| The Following User Says Thank You to b-man For This Useful Post: | ||
Buy a used pair; I see em occasionally at used construction site auctions for pretty cheap.
Two 1975 455 Grandvilles & '79 455 Trans Am ‘69 Camaro SS 396/375 (owned since ‘88) ‘67 Corvette 427/435 ‘23 Lexus LS500 awd ‘20 Audi R8 & ‘25 Toyota RAV4 (wife’s cars) ‘95 Ford F250 4wd 7.3 p-stroke & countless Jeeps & off road vehicles & motorcycles |
Consequences of a bad decision are clearly different than if you are your own boss. In theory, the risk for weakening the fork by straightening is low IF the bending was uniform along the fork AND the plastic deformation strain was low. If all the deformation happened in the tight root radius, risk for weakening by straightening is much higher. If the deformation strain is spread out along the fork, it will be much less likely to cause irreparable damage than if the strain was highly localized on the OD of that small root radius. But this is just theory and visual inspection might miss the truth. Not worth risking a failure if you are making a guess for your employer. Sirrotica - are there shops that can "certify" a repair by "proof load" testing? Or is fatigue risk a big factor that makes it difficult to certify a repaired fork? Just curious. Mike |
| The Following User Says Thank You to Shiny For This Useful Post: | ||
Watering Eyes Here! LMAO!!1
Had a really bad day today & then saw this....... I use my fork lift with the extended forks I purchased for loading, unloading & removing from the chassis engines, transmissions etc. If I bent one...I would back the dually inside the building & drive over it to make it back to straight, then would go onto the task at hand! Wouldn't post it on a forum or think twice about it! LMAO! God Bless Bill https://www.jalopyjournal.com/forum/...closed.614419/
"Jealousy is a Sad Pathetic Character Trait Generally Held By The Lazy, Immoral Dregs of Society" Your QUALITY Pontiac Transporter Since '83 1955 Chevy Alt. W.B. Gasser 1955 Nash Ambassador Cust Lemans 1957 T-Bird 1964 Grand Prix 1966 Catalina Conv 1966 Ambassador DPL 2dr 1966 Ambassador Cust. 2 DR 1967 Marlin 1967 Toro 1973 Nova Chassis Car 1992 Jag XJS Conv 1992 Jag XJS Coupe 2007 Cad XLR-V Supercharged Roadster 2008 Avalanche Southern Comfort Edition |
I've never seen or heard of any facility to test forks, if they were bent and noticed during a PM service the forks would be measured for wear and the bent one would be noted for replacement. If they were worn more than 10% of the vertical portion on the carriage they would also be recommended for replacement. We had gauges to test for wear. You'd be surprised how many forks are worn along the bottoms more than 10%, especially if the unit was in a high production setting. BTW, 10% wear along the bottom reduces the load limit by 20%. Proof testing would likely be similar in cost to replacement, plus the liability would be prohibitive. |
| The Following User Says Thank You to Sirrotica For This Useful Post: | ||
Have the other one bent the same.
One time a guy went under a bridge that was too low, he was hauling a FL, it snapped off both forks. If you could imagine. There is an adjustment on the chain on ea side to even the forks out.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Southern Hamtramck Institute of Technology , Alumni Put some 8” flakes and BFG’s on dude!, like everyone does🙄 Burds Literature, nOS factory Brochures, Glovebox literature, & black & blue freedom toppers. 1978 YEE 1995 Q45 #whoremembers |
My experience at a large Chemical company with lots of forklifts is exactly the same as Sirroticas. Forks get replaced not repaired.
73 T/A 455, 4speed |
Straightening shouldn't even be considered. Scrap metal now. I would also inspect the carriage for bends, broken welds, etc. It may just be the picture. But it looks like more than the fork is outta wack.
Thanks for the input everyone.
Honestly, I would've been in the "Just bend it back" camp. This was really interesting to read some of the more technical stuff regarding the forks.
"What the hell's wrong with freedom man? That's what it's all about." (Billy) "Oh yeah, that's what it's all about alright... but talkin about it and bein it, that's two different things." (George) Easyrider |
