Old 02-22-2025, 03:46 AM
Squidward's Avatar
Default 67 Firebird interior paint sheen?
All,
I will soon repaint the interior metal portions of my 67 - dash, upper part of doors, etc. It was painted by a previous owner many years ago after sanding with a brick, rock, or some other 20 grit abrasive.
I will properly sand/prime to fix that, but question is, what is the original sheen of the factory finish? I see lots of restomods with glossy interior paint, but it seems somewhat overstated. Was the factory paint a satin/semi finish?
Old 02-22-2025, 01:51 PM
camerjeff camerjeff is online now
I would say it is a gloss finish, I have attached some pictures of my Original paint 67 Firebird.
Its what I have on my HD I can take some pictures of the upper dash if you like.
ID:	647869   Click image for larger version
ID:	647870   Click image for larger version
Name:	Head Liner.jpg
ID:	647871   Click image for larger version
Old 02-22-2025, 02:13 PM
JLMounce JLMounce is offline
My understanding is that the bottom of the dash and the rest of the exposed metal painted surfaces should be a semi-gloss finish. The top of the dash should be a matte or satin finish.
This is how I did my interior, semi-gloss everywhere except for the top of the dash which is matte.
The matte finish on the top of the dash reduces glare on the winshield.
-Jason
1969 Pontiac Firebird
The Following User Says Thank You to JLMounce For This Useful Post:
Old 02-22-2025, 05:43 PM
I still think the lower dash and door tops are finished in a gloss but it could be a semi gloss, the top of the dash is defiantly a less gloss finish, but I don't think I would call it a matte finish maybe 20% gloss?
I took these picture today so the lighting is the same on these 3. My car is a 3 owner 105K mile Survivor
Name:	drivers door top.jpg
ID:	647880   Click image for larger version
Name:	Dash top 1.jpg
ID:	647881   Click image for larger version
Name:	dash top 2.jpg
Old 02-22-2025, 06:40 PM
einstein's Avatar
einstein einstein is offline
I seem to recall 60% gloss on everything metal below the dash pad and flat/matte above.
I know these things are documented somewhere. Might have been paint charts, but I don't recall which paint supplier
I don't know about the door upper as that's 67 only, my knowledge and literature is mostly 69 and a little 68.
Maybe ask in the Interior and Paint/Body forums.
Old 02-23-2025, 03:01 AM
Squidward's Avatar
Thanks, all. That helped. Makes total sense with the upper dash surface being duller. I was worried that a high gloss wouldn't look right on the lower dash and door stuff.
Old 02-23-2025, 07:53 AM
Try this:
Old 02-23-2025, 10:44 AM
Thanks John I think that pretty well nails it
