| Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
Vanishing Point Race Cars 1996 Pontiac Firebird. Full dash with gages, carbon fibre council, new 20 lb fire system, DL10 Data Logger, Mark Williams Modular Ford rear differential 4.30 gear, 40 spline spool and gun drilled axles. Santhuff rear shocks. Anti roll bar, new updated wheelie bars, new dual air chutes, Strange front struts. 6 lb Lithium Battery.
EZ Lifts All Pontiac solid alum block 4.310 bore All Pontiac solid alum heads w/extra bolts Copper inserts between center head chamber Titanium valves Jessel 1.9 Pro Series rockers Crowler billet crank 4.250 stroke GRP 3101-PRO rods upgraded bolts JE ProMod pistons, pins, rings, buttons Dailey Dry Sump, Peterson oil tank w/heater MSD Mag 44 ignition 14-71 Littlefield Blower w/Big & Ugly Hat Clearview Oil Filter System Rossler ProMod 3 spd Trans w/dump valve On slide rails to move back from the converter Chance Bolt Together Convertor Quick Shift Air Shifter w/clean neutral This build was completed in spring of 2024. It was built to be competitive in the Butler Frantic 4 at Norwalk Raceway. The car was built with the best components available.The car has one 1st gear test hit on it at Norwalk in summer of 2024. At my age I no longer have the energy needed to campaign this race car. Complete log book with all parts and build information included. I will help anyway I can to make the car run well. Email me at [email protected] for a complete parts list and pictures. |
| The Following 4 Users Say Thank You to Glenn Sedig For This Useful Post: | ||
