Old 02-22-2025, 03:56 PM
Glenn Sedig Glenn Sedig is offline
Default Pontiac Promod/Top Sportsman Drag Car
Vanishing Point Race Cars 1996 Pontiac Firebird. Full dash with gages, carbon fibre council, new 20 lb fire system, DL10 Data Logger, Mark Williams Modular Ford rear differential 4.30 gear, 40 spline spool and gun drilled axles. Santhuff rear shocks. Anti roll bar, new updated wheelie bars, new dual air chutes, Strange front struts. 6 lb Lithium Battery.
EZ Lifts
All Pontiac solid alum block 4.310 bore
All Pontiac solid alum heads w/extra bolts
Copper inserts between center head chamber
Titanium valves Jessel 1.9 Pro Series rockers
Crowler billet crank 4.250 stroke
GRP 3101-PRO rods upgraded bolts
JE ProMod pistons, pins, rings, buttons
Dailey Dry Sump, Peterson oil tank w/heater
MSD Mag 44 ignition
14-71 Littlefield Blower w/Big & Ugly Hat
Clearview Oil Filter System
Rossler ProMod 3 spd Trans w/dump valve
On slide rails to move back from the converter
Chance Bolt Together Convertor
Quick Shift Air Shifter w/clean neutral
This build was completed in spring of 2024. It
was built to be competitive in the Butler Frantic 4 at Norwalk Raceway. The car was built with the best components available.The car has one 1st gear test hit on it at Norwalk in summer of 2024. At my age I no longer have the energy needed to campaign this race car.
Complete log book with all parts and build information included. I will help anyway I can to make the car run well. Email me at [email protected] for a complete parts list and extra pictures.
Old 05-02-2025, 03:26 PM
EZ Lifts
MSD Mag 44 ignition
Pic of Promod
ID:	651130   Click image for larger version
ID:	651131   Click image for larger version
ID:	651132   Click image for larger version
ID:	651133   Click image for larger version
Old 01-21-2026, 04:08 PM
Default Promod TA
This race car is still for sale. I am willing to work with you on the price. Race it at Norwalk 2026. Starting price was $110,000. Will come down to $85000 obo
Thank
Glenn Sedig
815 441 0931
