Old 02-27-2025, 03:50 PM
joes455 joes455 is offline
Default Old faithful cam
Has anyone set up this cam up with 106 intk centerline vs 108?Thanks in advance
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 02-27-2025, 05:11 PM
steve25 steve25 is online now
Was that an intentional pun? :-)
Old 02-27-2025, 05:17 PM
i82much's Avatar
i82much i82much is offline
well going the other direction would be retarded.
Old 02-27-2025, 06:16 PM
Steve C. Steve C. is offline
Old Faithful ICL
https://forums.maxperformanceinc.com...d.php?t=735243
"Dave told me 106 - 108 with a new timing set"
Old information here:
The Following User Says Thank You to Steve C. For This Useful Post:
Old 02-27-2025, 06:18 PM
JB Eng Wis JB Eng Wis is offline
Ok ... It will run fine @ 106.....and will "retard" to 107 or 108 as timing chain relaxes
Old 02-27-2025, 07:01 PM
Thanks for the link steve,I'm running a 273 gear and hope this will work better with timing at 106.I still would like to perform a compression check.Prior install it had 180 I'm expecting 190 -195 ,if it goes higher then 200 I'll be going back to 108.
Old 02-27-2025, 07:19 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Go fast, see Elvis!
Old 02-27-2025, 07:31 PM
grivera's Avatar
grivera grivera is online now
My original OF1 is degreed in at 108, with 3.90 rear, 28” tire. Not operational just yet…
Will Rivera
Old 03-02-2025, 10:39 AM
Well this is strange, I performed a compression test and only got 160 psi,seems low.Was expecting 180 at least.Did test with engine on stand .May need to seat rings and then retest.
Old 03-02-2025, 11:07 AM
Stan Weiss's Avatar
What is your engine size and CR? The higher your CR the greater the change in cranking compression will be for a ICL change. A 10.0:1 455 should see an increase of a little under 5 psi going from 108 ICL to a 106 ICL.
Stan
Pontiac Pump Gas List
Old 03-02-2025, 11:24 AM
grivera's Avatar
Engine hot for the test?
Will Rivera
Old 03-07-2025, 12:39 PM
OK finally running again,feels a little more responsive off idle.Haven't made any full throttle stabs yet still breaking in,is a little noisy until lifters fill up.Will do a compression test soon,but curious if I will get legit readings due to the lifters compressing and closing the intake sooner
