Has anyone replaced the control arm bushings in the ebay 64-72 A Body tubular arms & have a part number or application?
You want the Global West bushings.
Uppers should be part 1030 and lowers should be 1055. I would call them to absolutely verify though.
| The Following 2 Users Say Thank You to JLMounce For This Useful Post: | ||
Thank you Jason, I think you’ve cracked the code on these arms. I’ve searched everywhere & no one can say what bushings to use. It looks like from your suggestion the bushings are for Corvette arms up to 1982 & full size Chevy arms up to 1970. I’m ordering the Moog versions to confirm since this is more for a cruiser car than protour feel. I’ll update this once I test fit the bushings, thanks!
Any update on which bushings worked? Also, which ball joints did you use?
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
I ended up selling the arms so never installed the bushings. I should have swapped them out first but didn’t get around to it.
1972 GTO |
