Hello!
Have an issue on my Bonneville -59. The cold lamp does not work then I've started the car cold. Have tested the hot/cold lamps by attach ground to the two wires at the sensor och the lamps light up fine. I'm going to replace the sensor so I attached the wires to the new sensor and the sensor to ground but then the lamp does not work. Ok, thought the new sensor was bad to I also tried an used sensor the I know is working but with the same result. Anyone that has a idea about what's going on?? |
