At what power level do you go to an aftermarket crank versus a stock one?
ive bought 2 or 3 forged cranks for motors i hope to make 800hp or more with, the way i understand, the block will go before the crank.
I think 800 HP on a stock block without filling the water jackets with hard block is pushing the limit.
Aftermarket forged only , don’t even think about a cast one because the factory cranks are better.
| The Following 3 Users Say Thank You to steve25 For This Useful Post: | ||
The factory N nodular iron cranks were pretty stout. I would think 500-600 hp would be no problem.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car. 79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.60 @ 126 so far... |
| The Following 3 Users Say Thank You to prostreet64 For This Useful Post: | ||
If between 5 and 6 hundred horsepower I’d be considering a forged crank.
Looking at what it costs to properly prep a stock crank you’re already about halfway there anyway.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
| The Following 4 Users Say Thank You to b-man For This Useful Post: | ||
| The Following User Says Thank You to 68WarDog For This Useful Post: | ||
Close to 650 hp and 300 shot on factory crank and block for years
no problem just a lot of fun. Thats not to say you can't break it but there pretty darn tuff. GT |
i tbought all the 455 cranks were N cranks. as far back as i can recall, even on these forums...stock N cranks was always better than aftermarket cast cranks. the aftermarket cast cranks won out on longer strokes at affordable cost...that said, until the first 450.00 forged cranks came out it was pretty common to read threads about guys spinning stock cranks close to 7k with good rods/pistons and in the 6-700hp range. id think 500hp would be nothing for your std crank
| The Following 2 Users Say Thank You to performerrpm For This Useful Post: | ||
Of course, it's spinning with Carrillo rods and Brooks 13:1 pistons.
Never been near a dyno, but the online ET to HP calculators say it's making between 550 and 560HP. So I also believe the factory 'N' cranks are pretty tough. Of course, our IAII 541 has a forged 4.5" crank in it..........but it's still on the stand........
Any one have Jim Hands book to post up how much abuse a 455 crank took that he has fail that he talks about?
I will do so later if no one else does, but the amount of time it took of getting beat on was astounding before it gave out! With lighter reciprocal parts getting use in builds these days I would say 650 is where I would draw the line in being very safe as long as your not planning to race the motor every weekend for 2 seasons. Prepping the crank ( polishing the crap out of it) will make a huge difference in longevity as will cryogenic treatment if theres a location close enough to drive it to. Tuning for no detonation I am considering a given. The SD455 acording to the engineer who designed it was made to run day and night at 6000 rpm with a good margin of safety, and these motors left the the factory with a cast crank, so just putting that out there.
so how much stronger is a $700 aftermarket forging vs a factory N?
| The Following User Says Thank You to srmmmm For This Useful Post: | ||
Using the factory N crank in my 455 build. Did 580/600 on the dyno. The build is too new to discuss real longevity yet, but so far so good.
Nothing crazy on the machining. The shop magged it, checked it for cracks and polished it. The crank was already 10/10, but did not need to go 20/20. Touched up the line bore and using a quality BHJ harmonic balancer. I have no concerns about this setup as it's not a race car that sees hard passes its entire life.
| The Following User Says Thank You to JLMounce For This Useful Post: | ||
This
| The Following 2 Users Say Thank You to PAUL K For This Useful Post: | ||
Here’s the service life that Jim Hands got out of a 455 crank.
135,000 miles before it came out of the donor car. 2500 mid to low 12 second passes. 8 years of hard street driving in 4000 lb car. Almost 2 years in 12 second nitrous powered 77 Can Am. Could anyone really expect more? Close examination of the pictures of the failed crank from his book look to me like it failed at internal sharp edges left by the factory drilling of the oil passage at there junction point.
| The Following User Says Thank You to steve25 For This Useful Post: | ||
Internal oil passages .... One time i ran a straight flute carbide reamer through a 455 crankshaft's oil holes not expecting to do very much i was very suprized at the amount of cutting debris ... and the reamer was same nominal size
........... The More You Follow The Herd The Less You Can Be In The Lead .......... |
| The Following 4 Users Say Thank You to Formulas For This Useful Post: | ||
I always run a long drill bit through the oil holes in all my cranks after hot tanking, and yes the crap that comes out many times had to make for some level of flow restriction.
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
| The Following User Says Thank You to hurryinhoosier62 For This Useful Post: | ||
